Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
MacBook Front Display Bezel
  • MacBook Front Display Bezel / White
  • MacBook Front Display Bezel / Black
4,99 $
4,99 $
Мы отправим сообщение, когда товар будет в наличии.
Manta Driver Kit
112 bits for every fix.
Upgrade Your Toolbox
Manta Driver Kit
Спецификации
Описание
Описание
Replace a scratched or cracked MacBook front display bezel with camera hole.
Совместимость
Совместимость
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Характеристики
Характеристики
Part #:
922-7776, 922-7598, 922-8009
Совместимость
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Истории ремонта
Фото профиля
Zachary Wheeling's Story Photo #750163
Моя проблема
MacBook Core 2 Duo 2.16 Ghz 4GB RAM 240GB Intel SSD 160GB Apple HDD..... Screen Bezel clips were broken and wanted to change color from black to white. Also wanted a dual hard drive as I had recently purchased an SSD to speed up my MacBook C2D and wanted to run three Mac OS's as well as a copy of . . .
Фото профиля
Моя проблема
classic cracking in the display bezel and topcase palmrest. Felt like the Mac desirved to be refurbished after the fond college memories
Моё решение
followed the online takeapart guide, was easy as 1 2 3
Мой совет
make sure to retain the plastic fitting clips when removing the old front bezel frame, they are needed in ord . . .
Фото профиля
Моя проблема
Spilled iced tea all over my upper case and my front bezel was showing some age
Моё решение
It went well thanks to the guides
Мой совет
Diy
Фото профиля
Моя проблема
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
Моё решение
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I fou . . .
Фото профиля
Моя проблема
Right and Left arrow keys stopped working
The actuator key below the track pad was sticking.
The bezel was cosmetic .
Mac Store wanted almost $400.00 to do the Fix
Моё решение
When I removed the screws with Fixit instructions The some of the screws were in the wrong holes. this unit had been fixed at a
"mac "re . . .
Фото профиля
Моя проблема
The screen in the MacBook (Early 2009) had no light. First I changed the inverter and inverter cable but still no light. So I decided to change the LCD panel as well and this did the trick.
Моё решение
I followed the guide to change the LCD panel and had no big problems.
Мой совет
Invest in proper tools! Screwdrivers and . . .
Фото профиля
Моя проблема
It had begun to crack in a few spots.
Моё решение
The repair went very well. I did not need to remove the screen to install the bezel.
Мой совет
Be extra careful with the small clips that help hold the bezel. They are delicate. Pry gently and try to avoid damaging the clips. Use a small flat blade to help install the clip . . .
Фото профиля
Моя проблема
MacBook mid-2007 13" screen cracked when lid pushed too far back. Front display bezel showed signs of wear so decided to replace it at same time.
Моё решение
Parts came on time and safely packed. Printed out guide and followed it religiously. Bought very good small screwdriver set at Home Depot for about $1 . . .
Фото профиля
Моя проблема
Because it was broken in half
Моё решение
Very well
Мой совет
Always buy from iFixIt.com
Показать еще
