Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Function Keys Late 2016 Case Components
Магазин
Grab a toolkit for your MacBook Pro 13" Function Keys Late 2016 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Не знаете, какая у вас модель? Узнать свою модель Mac
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Case / New / Dark Gray
Replace an upper case and keyboard compatible with the Late 2016 to Mid 2017 MacBook Pro 13 inch Retina Function Keys laptop.
199,99 $
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
69,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 13" MacBook Pro with Retina Display.
9,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Hinge Spring
Replace a damaged spring tension hinge bracket compatible with a Late 2016 or 2017 model 13" MacBook Pro with Retina display.
9,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Lower Case / Silver / New
Replace a scratched or dented lower case.
От 29,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Trackpad Cable Bracket
Replace the bracket that secures the trackpad cable connector to the logic board compatible with the Late 2016 to 2017 model 13 inch MacBook Pro Retina Function Keys lapt...
4,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Headphone Jack Cable Bracket
Replace the bracket that secures the headphone jack cable to the logic board in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
4,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Case Assembly / A-Stock / Silver / With Battery / No Trackpad
Replace an upper case, keyboard, or battery in your MacBook Pro 13 inch Retina Keys Late 2016 to Mid 2017 laptop.
449,99 $
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Hinge Covers
Replace the plastic covers for the display hinges.
14,99 $
MacBook Pro 13" Retina (Late 2016-2019) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2019 model 13" MacBook Pro with Retina Display.
5,99 $
Показ товаров 1 - 10 из 11
Информация об устройстве
Released in October 2016 with the Apple model number A1708 / EMC 2978, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). This model packs an Intel Core i5 and two Thunderbolt 3 ports.
The most common repairs with the 13" Late 2016 model MacBook Pro with Retina Display and Function Keys laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Function Keys Late 2016 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Function Keys Late 2016 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Function Keys Late 2016 earned a 2 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
