Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina Case Components
Магазин
Grab a toolkit for your MacBook Pro 13" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Не знаете, какая у вас модель? Узнать свою модель Mac
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Upper Case / New / Dark Gray
Replace an upper case and keyboard compatible with the Late 2016 to Mid 2017 MacBook Pro 13 inch Retina Function Keys laptop.
От 159,99 $
MacBook Pro 13" Retina (A1706, A1708, A1989, A2251) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2020 model A1706, A1708, A1989, or A2251 MacBook Pro 13" with Retina Display.
От 49,99 $
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly
Replace an upper case assembly that includes the backlit keyboard compatible with the Early 2015 model A1502 MacBook Pro 13" laptop. Part #661-02361.
От 199,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
49,99 $
MacBook Pro 13" Retina (Late 2012-Early 2013) Trackpad
Replace a trackpad compatible with the Late 2012 to Early 2013 model A1425 MacBook Pro 13" Retina laptop. Part #923-0225.
49,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case / New / Silver
Replace an upper case, keyboard, or touch bar compatible with the Late 2016 to Mid 2017 model 13" MacBook Pro Retina Touch Bar laptop.
От 169,99 $
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly / New / No Trackpad or Battery
Replace an aluminum Upper Case Assembly compatible with the Late 2013 to Mid 2014 model A1502 MacBook Pro 13" Retina laptop. Includes the backlit keyboard and may include...
От 44,99 $
MacBook Pro 13" Retina (Late 2016-2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with 2016 to 2020 model 13 inch MacBook Pro laptops.
3,99 $
MacBook Pro 13" Retina (Late 2016-2017) Display Hinge Spring
Replace a damaged spring tension hinge bracket compatible with a Late 2016 or 2017 model 13" MacBook Pro with Retina display.
9,99 $
MacBook Pro 13" (A2159, 2019) 1.4 GHz Logic Board with Paired Touch ID Sensor / 8 GB / 128 GB
Replace a damaged or malfunctioning 1.4 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
От 449,99 $
Показ товаров 1 - 10 из 54
Информация об устройстве
Late in 2012 Apple released the MacBook Pro 13" with a new Retina display having 2560-by-1600 resolution. The Retina Display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 13" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display repair guides for step-by-step instructions on how to make the fix.
