Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar Mid 2017 Case Components
Магазин
Grab a toolkit for your MacBook Pro 13" Touch Bar Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Не знаете, какая у вас модель? Узнать свою модель Mac
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
От 49,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case / New / Silver
Replace an upper case, keyboard, or touch bar compatible with the Late 2016 to Mid 2017 model 13" MacBook Pro Retina Touch Bar laptop.
От 169,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2020 ...
4,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
От 29,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Hinge Covers
Replace the plastic covers for the display hinges.
0,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case Assembly / A-Stock / Dark Gray
Replace an upper case, keyboard, touch bar, or battery compatible with the 2016 or 2017 model A1706 MacBook Pro 13" Retina Touch Bar laptop.
399,99 $
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
5,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with the 2016 to 2020 model 13 inch MacBook Pro Retina Tou...
3,99 $
MacBook Pro 13" Retina (Touch Bar, Late 2016-2018) Keyboard Cable Bracket
Replace a bent or missing metal bracket that secures the keyboard and upper case cable connector to the logic board in a 2016 to 2018 model 13" MacBook Pro with Retina Di...
3,99 $
MacBook Pro 13" Retina (Late 2016-2019) Touch Bar Display Cable Brackets
Replace a bent or missing metal bracket securing the touch bar interconnect cable connectors to the Touch Bar or the logic board in a 2016 to 2019 model 13" MacBook Pro w...
3,99 $
Показ товаров 1 - 10 из 13
Информация об устройстве
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
