MacBook Pro 13" Unibody Early 2011 Logic Boards
Grab a toolkit for your MacBook Pro 13" Unibody Early 2011 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Части, которые работают с MacBook Pro 13" Unibody Early 2011:
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 13” Unibody MacBook Pro laptop. Included Ports: FireWire 800, Thunderbolt (Mini ...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody A1278 model. Included Ports: FireWire 800, Thunderbolt (Mi...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.7 GHz Logic Board
Replace a 2.7 GHz logic board (motherboard) compatible with the MacBook Pro 13" Unibody (Early 2011-Late 2011). Included Ports: FireWire 800, Thunderbolt (Mini DisplayPor...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini Di...
Информация об устройстве
In February 2011, Apple refreshed the 13" MacBook Pro line by changing to the Intel HD Graphics 3000, increasing VRAM to 384 MB, and upgrading to Core i5 and Core i7 processors with PC3-10600 RAM. The Mini DisplayPort was also replaced (but still backwards compatible) with the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with the MacBook Pro 13" Unibody for Early 2011 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Early 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The MacBook Pro 13" Unibody for Early 2011 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Early 2011 repair guides for step-by-step instructions on how to make the fix.
