MacBook Pro 13" Unibody Late 2011 Logic Boards
Grab a toolkit for your MacBook Pro 13" Unibody Late 2011 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Части, которые работают с MacBook Pro 13" Unibody Late 2011:
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 13” Unibody MacBook Pro laptop. Included Ports: FireWire 800, Thunderbolt (Mini ...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody A1278 model. Included Ports: FireWire 800, Thunderbolt (Mi...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.7 GHz Logic Board
Replace a 2.7 GHz logic board (motherboard) compatible with the MacBook Pro 13" Unibody (Early 2011-Late 2011). Included Ports: FireWire 800, Thunderbolt (Mini DisplayPor...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini Di...
Информация об устройстве
The Late 2011 version of MacBook Pro 13" Unibody is virtually identical to the Early 2011 model except for a CPU and graphics upgrade. It features a Core i5 or Core i7 processor with PC3-10600 RAM. It also sports the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with the MacBook Pro 13" Unibody for Late 2011 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Late 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The MacBook Pro 13" Unibody for Late 2011 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Late 2011 repair guides for step-by-step instructions on how to make the fix.
