MacBook Pro 13" Unibody Logic Boards
Grab a toolkit for your MacBook Pro 13" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Выбери свою модель MacBook Pro 13" Unibody:
Части, которые работают с MacBook Pro 13" Unibody:
MacBook Pro 13" Unibody (Mid 2012) 2.5 GHz Logic Board
Replace a 2.5 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 100...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody A1278 model. Included Ports: FireWire 800, Thunderbolt (Mi...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 13” Unibody MacBook Pro laptop. Included Ports: FireWire 800, Thunderbolt (Mini ...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.7 GHz Logic Board
Replace a 2.7 GHz logic board (motherboard) compatible with the MacBook Pro 13" Unibody (Early 2011-Late 2011). Included Ports: FireWire 800, Thunderbolt (Mini DisplayPor...
MacBook Pro 13" Unibody (Early 2011-Late 2011) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Early 2011 to Late 2011 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini Di...
MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
Replace a 2.9 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Thunderbolt (Mini DisplayPort), 100...
MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
Replace a 2.26 GHz logic board (motherboard) compatible with the Mid 2009 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethern...
MacBook Pro 13" Unibody (Mid 2009) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Model A1278 Mid 2009 MacBook Pro 13" Unibody laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000...
MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 13" Unibody model laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT E...
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the MacBook Pro 13" Unibody (Model A1278) laptop. Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT E...
Информация об устройстве
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, and added an SD card slot. The 13" Unibody models continued through Mid 2012.
The most common repairs with the MacBook Pro 13" Unibody models are replacing a dead battery or upgrading the hard drive or RAM. Choose a model for more specific information.
The MacBook Pro 13" Unibody models require a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody repair guides for step-by-step instructions on how to make the fix.
