Отремонтируйте ваше устройство
Обучение ремонту
Магазин
MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
  • MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
499,99 $
499,99 $
Спецификации
Описание
Описание
This Late 2012 to Early 2013 MacBook Pro 13" Retina replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Часть сборки включает
  • 2560 x 1600 13.3" Retina LCD Screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
Совместимость
Совместимость
  • MacBook Pro 13" Retina A1425 Late 2012 to Early 2013
Характеристики
Характеристики
Part #:
661-7014
Size:
13.3"
Resolution:
2560x1600
Совместимость
MacBook Pro 13" Retina Display Early 2013
A1425 (EMC 2672) 2.6 GHz
A1425 (EMC 2672) 3.0 GHz
MacBook Pro 13" Retina Display Late 2012
A1425 (EMC 2557) 2.5 GHz
A1425 (EMC 2557) 2.9 GHz
Истории ремонта
Фото профиля
jimpandolfo's Story Photo #901875
jimpandolfo's Story Photo #901873
jimpandolfo's Story Photo #901878
Моя проблема
Coating was coming off my retina screen.
Моё решение
The web site instructions were spot on! The repair was easy and fun to do. I had 0 issues. Thanks!!!
Мой совет
As long as you follow the directions, it's an easy repair. Took me less than 30 minutes
Фото профиля
Phil Wymore's Story Photo #858008
Моя проблема
Cracked Retina display
Моё решение
It couldn't have been easier -- in fact it was actually fun. The tools were perfectly matched for each task and the instructions were very easy to follow.
Мой совет
Don't be intimidated
Фото профиля
Моя проблема
Crack in display
Моё решение
Very good, the only difficult part was to replace the new display and connect it with the first 2 screws.
Мой совет
Фото профиля
Моя проблема
I carelessly put a small crack in my previous screen and after getting an estimate from a shifty guy at the Apple store I would have been better off replacing the whole Macbook. I'm in college and I need to save the money.
Моё решение
The process was smooth and easy with excellent steps and pictures to help buls . . .
Фото профиля
Моя проблема
Cracked display.
Моё решение
Smoothly.
Мой совет
Must have proper screwdrivers (Torx 2, 5, 6, 7, and 8, I believe).
Фото профиля
Моя проблема
My old retina display was dying. I had a streak of dying pixels down the left side of my monitor
Моё решение
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid as . . .
Фото профиля
Моя проблема
The screen was damaged when the laptop was dropped
Моё решение
Screen replaced
Мой совет
I had someone experienced in repairing my laptop complete the repair. Very satisfied and happy with the outcome.
Показать еще
