MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
  • 360°
360
99,99 $
99,99 $
Спецификации
Описание
Описание
Replace the 2.26 GHz logic board in your MacBook Pro 13" Unibody (Mid 2009) and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Совместимость
Совместимость
  • MacBook Pro 13" Unibody A1278 Mid 2009
Характеристики
Характеристики
Part #:
661-5230
Speed:
2.26 GHz
GPU:
NVIDIA GeForce 9400M
Совместимость
MacBook Pro 13" Unibody Mid 2009
A1278 (EMC 2326) 2.26 GHz
A1278 (EMC 2326) 2.53 GHz
Истории ремонта
Фото профиля
Моя проблема
When to start system operative is it very slow, although it had already been replaced the HDD for SSD, and the flex is okay.
Моё решение
the original heatsink did not hunt with this board that I received
Мой совет
you should always to use anti-static bracelet
