MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / New
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / Used
  • MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / Without Bracket / New
  • 360°
360
44,99 $
44,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Replace a damaged hard drive cable in your Mid 2012 MacBook Pro 13" Unibody laptop computer with this part to fix the connection of an unrecognized drive.
Заметка
Some options do not include the hard drive bracket, so be sure to select the appropriate product for your needs!
Совместимость
Истории ремонта
Моя проблема
This is actually a computer I sold to a friend. 1 week after the fact he called and said it wouldn't boot, there was a folder with a question mark icon. He took it to another friend who replaced the hard drive, for $100. That hard drive "failed" also. This all sounded fishy to me.
I got the comput . . .
Моя проблема
After removing the hard drive and seeing that I could access the data easily and boot from it, i knew it was either the sata cable and/or the logic board. Sata cable was least invasive and least expensive so I went for that first.
Моё решение
All worked well. Computer is up and running
Мой совет
Take your time and follo . . .
Моя проблема
The previous repair cable failed within 8 months so I bought this one and we will see if the quality of it is better. So far it seems better built but will need to stand the test of time. I feel confident.
Моё решение
Easy. Very straight forward especially after having done this once before.
Мой совет
Do your research befo . . .
Моя проблема
The Apple people said I could handle it and it would be cheaper if I did it myself.
Моё решение
It went well. The computer works. Now I just have to figure out software updating then it will be like new.
Мой совет
I replaced a cable bracket in my macbook. Screws were tiny, Other then that it went off without a hitch. T . . .
Моя проблема
Hard drive would not boot while connected to the internal SATA cable but would boot correctly when placed into an external USB carrier.
Моё решение
The repair process was very easy. Remove the laptop bottom cover, unscrew and remove the hard drive hold down brackets, unplug the hard drive from the SATA cable the . . .
Моя проблема
A client gave me a mid-2012 MacBook Pro for recycling after he'd replaced it. The computer rarely would boot at all. It wasn't the hard drive.
I kept the computer around, loathe to recycle something that seemed close to working.
I had bought the new part to see if it improved another client's comp . . .
Моя проблема
My old SATA cable wasn't able to transfer files as fast as my new SSD's disk speeds (1/5th the speed)
Моё решение
Works great! My new SSD works find because of the new cable.
Мой совет
Buying a new SSD? Buy this cable. (Get the one with the bracket. It helps.)
Моя проблема
MacBook cable was damaged.
Моё решение
It was easy to replace and so far it works well.
Мой совет
If your Apple warranty is expired, try to repair this yourself rather than taking your MacBook to Apple.
Моя проблема
MacBook Pro worked fine with stock hard disk but refused to boot with SSD in place. Even erasing SSD was finicky and produced partitioning errors I'd never before seen.
Моё решение
Easy! In troubleshooting, I happened to have another client's same-model Mac on hand to briefly swap in their storage data cable and . . .
Моя проблема
Hard drive cable - MacBook pro was running loops with bad contact to harddisk. I checked this by reinstalling Lion OS X externally on a hard drive. This worked so my assumption that the cable was faulty proved itself.
Моё решение
I tried a cheap cable from amazon but people i tell you what a waste of time and m . . .
Показать еще
