MacBook Pro 15" Unibody Late 2008 Case Components
Grab a toolkit for your MacBook Pro 15" Unibody Late 2008 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Части, которые работают с MacBook Pro 15" Unibody Late 2008:
MacBook Pro 15" Unibody (Late 2008-Early 2009) Trackpad
Replace a trackpad compatible with the Late 2008 or Early 2009 model A1286 MacBook Pro 15" Unibody laptop. Part #922-9008.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Upper Case
Replace an Upper Case compatible with the MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009 laptop. Includes the backlit keyboard, trackpad, IR sensor, and battery le...
MacBook Pro 15" Unibody (Late 2008-Early 2009) Lower Case
Replace a scratched or dented lower case.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Access Door
Replace a scratched or dented battery access door on your laptop.
MacBook Pro 15" Unibody (Late 2008-Early 2009) Mid Wall
Replace the center bracing inside your machine.
Информация об устройстве
In October of 2008 Apple released the MacBook Pro 15" Unibody with a new aluminum case drilled from a single aluminum brick. This model introduced some features that were new to Apple laptops: dual video cards, one for power saving casual use and one for graphics-intensive processing, and a Mini DisplayPort replaced the full-size DVI display connector.
The most common repairs with Late 2008 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Late 2008-Early 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Late 2008 & Early 2009 repair guides for step-by-step instructions on how to make the fix.
