MacBook Pro 15" (Models A1150/A1211) LCD Panel
  • MacBook Pro 15" (Models A1150/A1211) LCD Panel
  • 360°
360
199,99 $
199,99 $
Спецификации
Описание
Описание
Replace a damaged or malfunctioning 15.4" 1440 x 900 LCD panel in your MacBook Pro 15" (Models A1150/A1211).
This LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
Совместимость
Совместимость
  • 1.83, 2 or 2.16 GHz (Model A1150) 15" MacBook Pros
  • 2.16 or 2.33 GHz (Model A1211) 15" MacBook Pros
Характеристики
Характеристики
Resolution:
1440x900
Diagonal Size:
15.4"
Совместимость
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Истории ремонта
Фото профиля
Моя проблема
My daughter accidentally crushed an LCD dead zone into her 15" Macbook Pro. Oopsy.
Моё решение
Swimmingly, except for a couple of wobbly bits. Specifically, one corner anchor of the screen bezel refused to screw down and the camera cable didn't reattach properly.
Мой совет
Softening the glue with heat would have helped, an . . .
Фото профиля
Моя проблема
The screen was broken due to a hard hit on the upper case lid.
Моё решение
The repair went very well and it worked right a way.
Мой совет
I just followed your DIY pictures and instructions online. Very good advice and easy to follow even though it is a difficult repair in general.
Фото профиля
Моя проблема
Left laptop in cold car and screen went bad. Tried to just replace inverter thing, but that wasn't it. Had to do the big LCD replacement.
Моё решение
SMOOOOOOTH! ifixit is great! Got the part(s), the tools and clear, well-written, well-depicted directions and fixed my Macbook. It was weirdly fun and gratify . . .
Фото профиля
Моя проблема
My daughter's laptop LCD display got broke because my other daughter decided to through the remote and hit and broke the screen.
Моё решение
The repair went without a hitch. I took it nice and slow. The only problem I had was with the spudger and using it to separate the pieces.
Мой совет
Get the spudger. It is good for k . . .
Фото профиля
Моя проблема
I drenched my old MBP with water, when I dropped a water bottle on it. I was getting it ready to ship to a buyer. After drying it out for three days, everything was fine except for the display.. It no longer functioned properly. I checked the inverter, it was fine, so determined it to be the dis . . .
Показать еще
