Отремонтируйте ваше устройство
Обучение ремонту
Магазин
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
  • MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
149,99 $
149,99 $
Спецификации
Описание
Описание
This Early 2011-Late 2011 MacBook Pro 15" Unibody replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
Replace a broken front glass or malfunctioning LCD display on your laptop. This screen assembly will renew the appearance of your front panel and eliminate the flickering on an aging display.
Часть сборки включает
  • 15.4" LCD screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
Совместимость
Совместимость
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
Характеристики
Характеристики
Part #:
661-5847
Diagonal Size:
15.4"
Совместимость
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
Истории ремонта
Фото профиля
Моя проблема
Bought a macbook pro as a refurbished device with a Matt screen, and the colors where washed out.
Моё решение
Pretty easy
Мой совет
When putting the new screen in the alignment for the hinges are a little bit tricky just some patience and you'll be golden
Фото профиля
Моя проблема
Screen glass, display and top cover damaged due hard object dropping onto my wife's computer when in closed position.
Моё решение
Repair went OK until having to remove cable display data cable retainer from the upper case. The retaining screw could not be removed however hard I tried - the result being that th . . .
