Отремонтируйте ваше устройство
Обучение ремонту
Магазин
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
299,99 $
299,99 $
Спецификации
Описание
Описание
Replace a broken or damaged upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 MacBook Pro 15" Unibody laptop.
Часть сборки включает
  • Upper Case
  • Backlit Keyboard
  • Battery Level Indicator
Совместимость
Совместимость
  • MacBook Pro 15" Unibody A1286 Early 2011 to Mid 2012
Характеристики
Характеристики
Part #:
661-5854, 661-6076
Совместимость
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2012
A1286 (EMC 2556) 2.3 GHz
A1286 (EMC 2556) 2.6 GHz
A1286 (EMC 2556) 2.7 GHz
Истории ремонта
Фото профиля
kennyfoner's Story Photo #246171
Моя проблема
Фото профиля
Моя проблема
The keyboard had keys that weren't working.
Моё решение
Thanks to the repair guide, the repair went very smoothly.
Мой совет
1. Print out the guide and number little plastic baggies with the step number screws and small parts.
2. The trackpad connect/disconnect seemed to be missing, look it up on YouTube.
3. Take you . . .
Фото профиля
Моя проблема
Coffee everywhere.
Моё решение
Flawless. Took about 1.5 hours. I had already had this thing apart a few times so I felt like an expert... probably would have taken longer otherwise.
Мой совет
- An empty icecube tray with post-it notes is a great way to keep track of screws and small parts along the way.
- Photos are a goo . . .
Фото профиля
Моя проблема
My son spilled a glass of water on my wife's 2011 early macbook pro. The keyboard and trackpad no longer behaved properly
Моё решение
The repair took a long time. It was difficult. But in the end it was successful.
Мой совет
Take your time. It is a good idea to have an egg carton or ice tray (or two) to keep screws sorted . . .
Фото профиля
Моя проблема
A client called with an issue.. "I spilled a DR Pepper on my my Macbook Pro *last week* and the keyboard stopped working. I used it with an external but now I get nothing." So, it's iFixit to the rescue. I searched for a replacement but all the pieces separate were just outrageous, but iFixit had it . . .
Фото профиля
Моя проблема
Well the wife forgot the Mac was nearby while watering a plant and that was all it took. She didn't turn it off and tried to shake the water out. I let it sit for a few day after getting the water out of it, but the keyboard was toast.
Моё решение
All went pretty much according to the guide. The display cable wa . . .
Фото профиля
Моя проблема
I spilled wine on my laptop keyboard. It worked fine initially, but by the next morning, keys would not function and it became impossible to use. Not wanting to buy a new machine or send off the computer to Apple for an expensive repair, I bought the parts and tools straight from iFixit. I found . . .
Фото профиля
Моя проблема
My MacBook Pro's upper case didn't look to good, after it fell like 1 meter. The internal parts survived the drop without any damage - yay!
Моё решение
Definitely not an easy repair. The repair took me more than an hour.
Мой совет
You'll need a good brain or some sort of system to know, where which screw goes...
Фото профиля
Моя проблема
I spilled coffee over keyboard. So the keyboard didn't work anymore.
Моё решение
With the instruction on ifixit website, it was quite easy and nothing complicated. Just needed proper tools and took time for me. Because it was the first time that I repair my computer by myself.
Мой совет
The most difficult part for me was t . . .
Фото профиля
Моя проблема
I spilled a soda all over my laptop. After drying it out, the only problem was the keyboard no longer worked correctly. Very sticky keys.
Моё решение
It was great. Followed the directions to a tee. Worked perfectly.
Мой совет
GET THE TOOLS... Tried to take apart some of this with my own tools and stripped two screws.. . . .
Показать еще
