MacBook Pro 17" Model A1212 Display Components
Grab a toolkit for your MacBook Pro 17" Model A1212 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Части, которые работают с MacBook Pro 17" Model A1212:
MacBook Pro 17" (Models A1151/A1212/A1229) Display Data Cable
Replace a damaged or malfunctioning cable connecting the LCD panel to the logic board.
MacBook Pro 17" (Model A1151/A1212) Display Inverter
Replace a malfunctioning inverter board in a 17" MacBook Pro. A bad inverter can cause a dead backlight.
MacBook Pro 17" (Model A1212) Clutch Cover
Replace a faulty, cracked or broken LCD hinge clutch cover on your MacBook Pro 17".
MacBook Pro 17" (Model A1212) Antenna Cover
Replace an Antenna Cover compatible with the A1212 model 17" MacBook Pro laptop. This part houses the AirPort antenna cable assembly within the clutch cover.
Информация об устройстве
Introduced in October 2006, the model A1212 of the MacBook Pro 17" has a Core 2 Duo processor, a speed improvement compared to its predecessor. Connectors on this model include an ExpressCard/34 slot, Gigabit Ethernet, FireWire "400" port, Firewire "800" port, three USB 2.0 ports, optical digital audio in/out, and DVI out.
The most common repairs with the model A1212 17" MacBook Pro are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 17" Model A1212 Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 4 GB of RAM.
Once you've bought your parts and tools, check out iFixit's A1212 MacBook Pro 17" repair guides for step-by-step instructions on how to make the fix.
