MacBook Santa Rosa/Penryn Fan
  • MacBook Santa Rosa/Penryn Fan
29,99 $
29,99 $
Спецификации
Описание
Описание
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your MacBook Santa Rosa/Penryn model to overheat and eventually damaging your processors. Replace a defective fan to fix overheating problems or to keep your laptop running quietly.
Includes:
  • Fan
  • Surrounding Metal Bracket.
Совместимость
Совместимость
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
Характеристики
Характеристики
Part #:
922-8273
Совместимость
MacBook Core 2 Duo
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
Истории ремонта
Фото профиля
Моя проблема
My daughter's Mac sounded like a lawnmower when it got hot.
Моё решение
Repair was relatively straightforward following the guide on iFixit.
Мой совет
Some of the steps refer to a #0 Philips but a smaller screwdriver works better. Watch out for the screws behind the memory cover. When replacing, use light pressure to get t . . .
Фото профиля
Моя проблема
My hard drive finally went up after 8 years. When I opened up my Mac to clean out dust, I noticed my fan seemed off... Considering it went from loud to silent overnight. I tested it and it was also in need of replacement, so I ordered the part.
Моё решение
Easy as pie. The guide is 100% accurate and the screws a . . .
Фото профиля
Моя проблема
La ventola, oltre a essere rumorosa, iniziava a perdere giri e le temperature salivano troppo; dopo anni di servizio era arrivata al capolinea.
Моё решение
Dopo la sostituzione il computer è tornato silenzioso e le temperature sono nuovamente sotto controllo.
La prima ventola che mi hanno spedito si è rivelata . . .
Фото профиля
Моя проблема
LAPTOP OVER HEATING AND SHUTTING DOWN, fan not blowing
Моё решение
I ordered part from Ifixit. I had previously replaced my keypad with new one from IFIXIT and directions I found on youtube. So I had and idea on how to disassemble. I took my laptop to a computer repair store, he said not busy at all. Big mistak . . .
Фото профиля
Моя проблема
The fan in my 2009 Macbook broke down; we went to iCentre here in The Netherlands who claimed the main board broke down; yes, for EUR 1100,- we could replace it. AND .. they had a nice action right that moment for a new Macbook Pro blah blah blah…
Ofcourse we did not go for their stories and w . . .
Фото профиля
Моя проблема
My MacBook Santa Rosa was heating and the noise of the fan was too loud.
Моё решение
I've change thermal paste and fan with a new one. The fan replacement wasn't necessary, the old one was in good shape. The thermal paste replacement has reduced the heating.
Мой совет
Do not replace the fan heaven if you think your MacBook . . .
Фото профиля
Моя проблема
So the problem was not even the fan, it was the inverter, SO while changing the inverter i thought it would be a good idea to clean out the dust in the fan and under the board. Turns out an air compressor at max speed will destroy a macbook fan, so while i was fixing one thing, i broke another, So i . . .
Фото профиля
Моя проблема
making a loud noise
Моё решение
followed the instructions on the guide and it was very straightforward
Мой совет
I taped each set of screws onto a piece of printer paper and labeled them as i went, which made them easy to keep track of.
Показать еще
