Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
MacBook Unibody (A1342) Trackpad
  • MacBook Unibody (A1342) Trackpad
  • 360°
360
74,99 $
74,99 $
Мы отправим сообщение, когда товар будет в наличии.
Manta Driver Kit
112 bits for every fix.
Upgrade Your Toolbox
Manta Driver Kit
Спецификации
Описание
Описание
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Unibody (Model A1342) laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Совместимость
Совместимость
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Характеристики
Характеристики
Part #:
922-9551, 922-9175, 661-9551
Совместимость
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
Истории ремонта
Фото профиля
Моя проблема
The track pad went from not clicking to moving around sporadically while you tried to click on anything.
Моё решение
It was very simple when following the directions.
Мой совет
After installing the track pad dont screw on the bottom immediately. Turn on the computer and check the 'clickage'. You might have to tighten or lo . . .
Фото профиля
Моя проблема
I helped my niece purchase her first used computer. When it arrived the trackpad wouldn't click. Instead of sending it back for a refund and realizing we would lose the shipping to and from and then not have a computer, I decided to go ahead and replace it myself.
Моё решение
Part was delivered in a timely manne . . .
Фото профиля
Моя проблема
Using ifixit repair guide I bought and installed a new trackpad.
Моё решение
Following the guide It was easy and problem solver in 15 minutes.
Мой совет
Ifixit, The right guide at The right place with the right parts!
Фото профиля
Моя проблема
Old and dead trackpad.
Моё решение
Only took ten minutes!
Мой совет
Works like new! Took me ten minutes to replace the trackpad.
Will order again from iFixit as they use quality parts.
Фото профиля
Моя проблема
My white unibody macbook was having problems with the trackpad. After days of searching the internet, trying software fixes, cleaning, checking battery, etc, nothing worked. I finally decided to go for it and buy a new replacement Trackpad with screws, the #00 Phillips Screwdriver, and the Y1 Tri- . . .
Фото профиля
Моя проблема
Trackpad clicker didn't work
Моё решение
The instructions were very clear and replacement went easy.
Мой совет
After installing the new trackpad the clicker still didn't work. I took it apart and noticed an adjustment screw that actuates the detent. I increased it and then it worked great. I didn't bother to try the old tr . . .
Фото профиля
Моя проблема
The battery swelled in the middle so much that it pushed the track pad up our of the computer.
Моё решение
Trackpad replacement seemed at first not to work, new pad was also out of alignment, but shifting the strips that hold it in slightly solved the problem and the track pad aligned. Worked perfectly. Putting . . .
Фото профиля
Моя проблема
My trackpad lost it's clicking ability
Моё решение
Replace with a brand new trackpad bought from www.ifixit.com
Мой совет
Please don't rush with any of your repairs. That's what I got from my past and present experiences.
Фото профиля
Моя проблема
My son dropped his phone onto his trackpad and chipped the corner of it.
Моё решение
We received the part and tool within a couple of days. I reviewed the online repair process and ten minutes later we were up and running again.
Мой совет
I would definitely use Ifixit again and recommend the online tutorials. They are ea . . .
Фото профиля
Моя проблема
My MacBook track pad was acting up. Unable to click, not very responsive to touch.
Моё решение
The repair process went smooth thanks for the useful detailed guide and all the tools and accessories provided by iFixit.com.
Мой совет
If the track pad just not clickable (or having trouble clicking), just need to readjust the . . .
Показать еще
