Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver / iFixit - Made in Germany
  • Flathead 3/32" or 2.5 mm Screwdriver / Moody - Made in USA
6,99 $
6,99 $
Мы отправим сообщение, когда товар будет в наличии.
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Спецификации
Описание
Описание
Use this precision flathead screwdriver for electronics repair and DIY projects. It's the most basic screwdriver you'll need in your toolkit to fix laptops, small home appliances, and electronics. The small, flat screwdriver blade is also known as the "slot", "common", or "standard" screwdriver.
The iFixit flathead screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision flathead screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Истории ремонта
Фото профиля
Моя проблема
Wifi, Bluetooth and GPS weren't working properly
Моё решение
After changing this part, everything works perfectly.
Мой совет
It's easy when you follow ifixit instruction.
Фото профиля
Моя проблема
The phone is 3+ years old and the battery would die in 3 hours of continuous usage. It also wouldn't charge unless you bend the lightning cable into the dock connector at an angle and keep it that way which is (holy ####) extremely frustrating and damages the appliance.
Моё решение
The repair itself went with a . . .
Фото профиля
Моя проблема
... is the Multi Tool Roll does not come in fashion colors. I would reorder as soon as I knew I could get a green one
Моё решение
Мой совет
... is the Multi Tool Roll does not come in fashion colors. I w . . .
Фото профиля
Моя проблема
no charge
Моё решение
fantastic
Мой совет
non ascoltare solo apple
Фото профиля
Моя проблема
Broken hard disk cable
Моё решение
It took only 5 minutes. Easy, fast, secure and now it's working! Don't be shy to repair something by yourself. And I've saved money!
Мой совет
First of all, practice, get familiar with your mac. Watch tutorials.
Фото профиля
Моя проблема
Power button was not working, and the battery was failing.
Моё решение
It was ok. The battery was rather hard to peel out, but after that, the power button procedure was ok.
Мой совет
The guide says to un-hinge the power button before the cable is detached from the back case. I found that I had to take the volume buttons . . .
Фото профиля
Моя проблема
My aunt forgot the take out of the pocket her iPhone 5S before putting the jeans in the washer machine.
Моё решение
There was no sign of sulfate or sparks on the logic board pins. We need to change the Dock port and probably the Battery but I am waiting on her desicion to spend $80 and it may be work or not.
Мой совет
Yo m . . .
Фото профиля
Моя проблема
The 1TB hard drive in my 2011 iMac started failing. Luckily I had everything backed up on externals. I was super excited to see that iFixit had a dual hard drive kit, so I ordered that plus a 500GB SSD for my boot drive and a 3TB HDD for bulk storage.
Моё решение
The repair went amazingly well. A co-worker helpe . . .
Фото профиля
Моя проблема
Upon visiting the Apple store to complain about the useless power button that mysteriously stopped working on my iPhone, I was told that my only option was to purchase an expensive "out of warranty" replacement. Fortunately, after researching the problem, I chose to buy a repair kit from iFixit ins . . .
Фото профиля
Моя проблема
cant afford a new replacement phone
Моё решение
repair went fine
Мой совет
dont need to remove the battery
Показать еще
