Heat Gun
  • Heat Gun
  • Heat Gun
Heat Gun
Heat guns may produce residual smoke when turned off the first few times and should always be used in a well-ventilated area.
19,99 $
19,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Great for reflowing solder and melting adhesive.
  • The power of fire in the palm of your hand (except for the part where flames actually come out).
  • 1500W Heat Gun needed for many different repair processes.
  • Can be used to loosen adhesive holding device components in place, or to reflow solder to repair soldered connections.
High and Low Heat settings
  • Low setting reaches 570/300 degrees F/C.
  • High setting reaches 1112/600 degrees F/C.
The high setting can ignite things. It can also burn you. So watch out!
For the professional heat gunslinger, check out our pro model, the Hakko HJ5000.
Available for shipment only to the USA due to voltage requirements.
Истории ремонта
Steven Rice's Story Photo #815542
Steven Rice's Story Photo #815544
Моя проблема
My friend dropped her phone in a parking lot.
Моё решение
I do NOT like how this phone was constructed. I was actually maimed in the process of repairing this thing. It uses these tiny little pins to hold a metal frame onto the screen assembly. It is a horrible design. I ended up getting one of those stupid litt . . .
Моя проблема
3 year old dropped it and shattered the screen
Моё решение
again- super easy, with the right tools. I tried with cheap picks and spudger that came with the replacement screen i got from ebay...big mistake. the picks broke with half inside and half outside the case. the cheap spudger bent and was worthless. w . . .
Моя проблема
Charging was intermittent and battery runs out fast - now all good with the replacement parts.
Моё решение
Doing both of these at the same time is a good idea. Good parts, good repair.
Мой совет
I grabbed a BIG local business advertisement magnet from my fridge and used that up side down for all of the screws and parts. . . .
Моя проблема
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
Моё решение
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip v . . .
Моя проблема
My Galaxy Mega 2 had a shattered screen.
Моё решение
The repair is pretty easy as long as you take your time removing the glass. It's just held together with tape so just heat it up a little around the edges and use a pick or another small tool and run it along the sides and off she comes.
Мой совет
Take your time and he . . .
Моя проблема
RROD
Моё решение
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
Мой совет
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in t . . .
Моя проблема
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
Моё решение
Repairs go a lot quicker with the right tools.
Мой совет
Make sure you have the ri . . .
Моя проблема
I fixed it because it ha front and back screen broken.
Моё решение
The repair went great it's fixed.
Мой совет
None i did it on my own.
Моя проблема
The screen shows only snow.
Моё решение
The iFixIt repair components worked fantastically! I was able to use the heat gun to melt the adhesive holding the touch pad digitizer to the iPad frame. i used: the set of picks to help separate the digitizer from the frame without damaging the plastic ring around the c . . .
Моя проблема
Screen is cracked.
Моё решение
Haven't do the repair yet.
Мой совет
Don't drop your laptop.
Показать еще
