Heavy-Duty Spudger
  • Heavy-Duty Spudger
  • 360°
360
Heavy-Duty Spudger
4,99 $
4,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Poke and prod like you mean it.
  • Thicker variant of the official "black stick" that Apple Certified Technicians use to repair Apple computers.
  • 6" long antistatic nylon probe with one flat end and one pointed end.
  • Flat end can be used to disconnect connectors, remove thermal paste from heat sinks, pry off components, or aid in soldering.
  • Pointed tip is handy for unlocking ZIF connectors and poking your siblings.
Истории ремонта
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
Моя проблема
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
Моё решение
It went smooth, thanks to iFixit guides, videos, and tools
Мой совет
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
Моя проблема
Battery would last about 4 hours from a full charge.
Моё решение
super simple, took about 45 minutes from opening ifixit.com to turning the phone on again.
Мой совет
get good tools from ifixit first, they made all the difference.
Моя проблема
My battery was draining very fast when it got to 30% and the lighting connector was failing
Моё решение
The repair took about 3 hours in two sessions. The last step of the lighting connector assembly replacement guide was missing the step at the end to separate the microphone cable from the plastic microphone i . . .
Моя проблема
Got my old iPhone 5 back in shape to let the kids share
Моё решение
Piece of cake. I have repaired a couple of other phones (with iFixit's help!) so I knew what to expect.
Мой совет
Follow the online guides! They tell you how to go and what to expect. I prefer the text with pictures, but there are videos too.
Моя проблема
My 18-month-old launched her Mom's iPhone 6 in the toilet, and then started crying, haha. I was at work when it happened, but Mom said that when she pulled it out of the toilet, she tried to turn it off but wasn't able to - and then she said it got hot... really hot. So, I figured that the battery . . .
Моя проблема
WiFi would work when MacBook was cold then stop later
Моё решение
Great! It's working again and the instructions on iFixIt's web site were perfect.
Мой совет
I, for some reason, always considered Macs untouchable for repair even though I've routinely opened and fixed Windows PCs for years. That is gone! Macs are fixable! W . . .
Моя проблема
Battery was original and only charging to 67% of original capacity. Mac Superstore wanted $150.00 for replacement. With iFixit instructions and their excellent pentalobe driver, I did the replacement in 30 minutes, for a total of $75.00 including the battery.
Моё решение
The repair was without any issues. The iF . . .
Моя проблема
Computer refused to boot which was narrowed down after many other suggested remedies to a defective power supply. Replacing the power supply was not something that I had ever done before. But with the very detailed description given by Chris Green led me to a successful disassembly and removal of th . . .
Моя проблема
Only had one ear bud (also one speaker when using accessory on car radio).
Моё решение
One hour had iPod apart,changed out earphone jack and battery (figured y not while I had it apart) and back together.
Мой совет
Plastic separaters weren't really used,small putty knife,metal AND plastic spudgers are a must. 00 Phillips s . . .
Моя проблема
Battery 6+years old, finally required a nonstop plug in charge. Basically, a desktop laptop. Slow and lots of beach balls was a normal function.
Моё решение
So, I scouted this iFixit site and logged it for later. After reading many reviews. I was sold on the battery for sure. The information was spot on. Many re . . .
Показать еще
