JIS Driver Set
  • JIS Driver Set
  • JIS Driver Set
JIS Driver Set
19,99 $
19,99 $
Мы отправим сообщение, когда товар будет в наличии.
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Спецификации
Описание
Описание
This is our set of hard to find JIS drivers in #000, #00, #0, #1 sizes. Japanese Industrial Standard (JIS) screws are very common in personal electronics from digital cameras to RC Helicopters. JIS screws are often marked by a single dimple pressed into the screw head.
JIS screws are not designed to "cam-out" or strip the head when overtightened like a Phillips screw, and can be damaged if a Phillips driver is used. JIS drivers can be used in both JIS and Phillips screws with no damage.
This made in the USA set of 4 JIS drivers matches our Professional line of screwdrivers and has ergonomic swivel top ESD safe handles.
Истории ремонта
Фото профиля
Edward Wagner's Story Photo #1369776
Моя проблема
Yesterday, smoke rolled out of this aircraft cockpit printer as soon as the power came on. The power supply failed and the transformer belched smoke. The stench was incredible.
Моё решение
The maintenance manual includes a service bulletin detailing the replacement of the old power supply with a newer, more reli . . .
Фото профиля
Моя проблема
Battery went from lasting 9 hours to 2 hours. Can't say if new battery will last longer yet until it's had a chance to fully charge.
Моё решение
Easy enough to take out screws and pry open the back. Gently removed old battery and slid in new one. I looked at a short video first, but it was more reassuring . . .
Фото профиля
Моя проблема
I was given a Yashica Mat 124G camera that needed a viewfinder cleaning badly.
Моё решение
The Moody JIS driver set were exactly what was needed to remove the viewfinders very tiny micro screws to access the internal mirror for cleaning. The tools worked perfectly and would not have been possible without the ri . . .
Фото профиля
Моя проблема
Replace the hard drive for my iMac 21 inch
Моё решение
Smooth without a problem following step by step guide I end replacing the hard drive after I made a clone version of the old hard drive to the new upgraded hybrid 2 T
Мой совет
You have to have the right tool for the right job.
The only inconvenience is to find my . . .
Фото профиля
Моя проблема
Screen was cracked
Моё решение
Brilliant thanks to ifix it guide
Мой совет
Not hard whatsoever as long as you have the tools and tech savvy experience
Фото профиля
Моя проблема
Now I can fix all my iPhone, iPad and iPod easier than before and I will buy some more tools to make high qualities works, thank you!
Моё решение
Everything Ok!
Мой совет
Be careful with your device before it breaks.
Фото профиля
Моя проблема
The device was still relatively useful and the repair isn't too hard.
Моё решение
Quite easily - the hard part is getting the case apart.
Мой совет
Use the metal thin tools to release the plastic bezel - the cable to the digitizer is super fragile so be careful removing the bezel after releasing it.
Показать еще
