Lead-Free Solder
  • Lead-Free Solder
Lead-Free Solder
4,99 $
4,99 $
Мы отправим сообщение, когда товар будет в наличии.
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Спецификации
Описание
Описание
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added.
  • Lead Free Solder. Coiled into convenient dispensing tube.
  • Melting point of 446/230 degrees F/C works well with our Soldering Kit.
Specifications:
  • Material: 99.3% SN, 0.7% Cu, rosin core
  • Weight: 0.5 oz / 14 g
  • Diameter: .04" / 1 mm
  • Melting Point: 446 ° F / 230 °C
Истории ремонта
Фото профиля
run4da's Story Photo #159336
run4da's Story Photo #159335
run4da's Story Photo #159338
Моя проблема
Battery was not holding a charge
Моё решение
I was definitely scared about attempting this project. The first challenge (prying open the antennae cover) was very daunting. I've uploaded a pic for illustration purposes - A is where I started to pry open the case, and B is the correct location for prying open the . . .
Фото профиля
Моя проблема
Broken wire left the right side with no audio.
Моё решение
I've never soldered any actual damaged electronics before but it was a simple process and I nailed it first go after a few bead test right beforehand.
Мой совет
Research and understand what you are doing before handling soldering equipment near electronics. I had n . . .
Фото профиля
Моя проблема
only 2 year old Kindle Fire . . . not charging
Моё решение
Not well - found problem, but wasn't able to fix it.
Мой совет
Don't buy a Kindle Fire!
Фото профиля
Моя проблема
I teach an ipad repair class to a group of 8th graders. This order was just to replace some tools. We are going to give the isesamo tool a try. Our best tool so far has been a metal spudger. It has a triangular end an a curve spatula end. You sell one that looks like it but the spatula end is to du . . .
Фото профиля
Моя проблема
the ground connection was broken and l put it in the shop to get the screen fixed and the shield the up by the display chip was gone the iphone work and l could hear sound but no picture and l looked up the iphone connection and the shield and the connection was gone so l have been look for the old . . .
Фото профиля
Моя проблема
My son has had his iPod touch for about 2 or more years and the battery was at a point that the unit would not hold a charge for very long. He uses this thing continuously and it is important to him. I had seen on iFixit that you had a replacement battery and the tools/instructions on how to do it . . .
Фото профиля
Моя проблема
After charging overnight my battery would go to red line in a few hours.
Моё решение
The repair went very smoothly. The hardest part was getting the ipod apart. The 7 Philips screws were difficult. Of the 7, 5 came out ok, but 2 had head damaged by the time I was done.... but there was enough left to reassemb . . .
Показать еще
