Mac mini Logic Board Removal Tool
  • Mac mini Logic Board Removal Tool / Stainless Steel
4,99 $
4,99 $
Мы отправим сообщение, когда товар будет в наличии.
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Спецификации
Описание
Описание
  • Simple tool pries the logic board free to allow access to the hard drive in 2010 to 2014 Mac minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
Совместимость
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
Mac Mini Late 2014
1.4 GHz (Dual i5)
2.6 GHz (Dual i5)
2.8 GHz (Dual i5)
3.0 GHz (Dual i7)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
Show 1 more device
Истории ремонта
Фото профиля
Моя проблема
Upgrade to SSD
Моё решение
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
Мой совет
Note in the guide to reformat the SSD before installing into the Mac mini
Фото профиля
Моя проблема
replaced HDD with SSD
Моё решение
did not need tool to remove logic board but screen did not fit back could not use one screw
Мой совет
take risks but use good tools
Фото профиля
Моя проблема
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
Моё решение
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
Фото профиля
Моя проблема
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
Моё решение
"Repair" its . . .
Фото профиля
Моя проблема
My original 500GB hard drive was very SLOW .
Моё решение
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
Мой совет
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
Фото профиля
Моя проблема
The hard drive was to slow - change it to a SSD
Моё решение
Followed the repair guid for harddisk installation, and the guide was really helpful.
Мой совет
Take your time and read the guid carefully. If you do, you will not go wrong
Фото профиля
Моя проблема
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
Моё решение
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
Фото профиля
Моя проблема
Slow mechanical hard drive - upgrade to SSD.
Моё решение
Went smoothly.
Мой совет
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
Фото профиля
Моя проблема
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
Моё решение
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
Фото профиля
Моя проблема
I thought I could live with a slow spinning drive - I couldn't...
Моё решение
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
Показать еще
