Metal Spudger Set
  • Metal Spudger Set
  • Metal Spudger Set
Metal Spudger Set
7,99 $
7,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Four times the brawn.
  • Any fixer knows that moment when you're stuck needing that one tool for the job—be prepared for the moment before it hits, with our assortment of four sturdy metal spudgers.
  • Easy-grip handles of just the right length for comfort and leverage.
  • Just the right amount of spring to pop out components and pry up against sticky adhesive.
Kit Contents:
  • Classic Metal Spudger - the tried and true original
  • Single Flat - with an extra long blade, great for iPad batteries
  • Small Pointed - reinforced and thick on both ends, good for scraping
  • Classic Wide - wide and slightly curved with rounded and pointed ends
  • Fitted Pouch - flexible plastic tool roll to keep your spudgers at the ready
Be sure to exercise caution when using these tools. With their great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Истории ремонта
Моя проблема
the right side headphone jack didn't work
Моё решение
Difficult but i did replace it in about 2 hours
Мой совет
just follow the instructions, they are great !
Моя проблема
Need to replace my existing battery pack. It got bulky and blocked my trackpad to function properly.
Моё решение
The repair was great. Easy to follow instruction from ifixit was no hassle. Only took me 10-15 mins to fix my mac and works like a Pro.
Мой совет
Everything was perfect.
Моя проблема
Simple screen replacement. I watch videos and look at teardowns to prepare for those little things smartphones are so full of. I replaced the screen because it was cracked (bought it that way). No display but the soft-keys did light up.
Моё решение
The repair went fine. I had to salvage the frame. Tedious work . . .
Моя проблема
I'm hard on phones and iPads. I can't even wear a watch. It ends up scratched, dented or in pieces within 6 months.
Моё решение
It's the second time for the iPad mini digitizer so it was much easier. First time for the phone and that was simple too.
Мой совет
The one recommendation I have is read the step by step instruc . . .
Моя проблема
The WiFi on my wife's iPad 1 suddenly died. No Wifi signal and no access points showed at all. I researched the repair and found a possible solution on the iFixit website, so I decided to give it a try and order the WiFi/Charging port part. I also learned that the display clips frequently break w . . .
Моя проблема
iPad repair
Моё решение
Got these just in time for my iPad repair. Made the job MUCH easier!
Мой совет
Not a must have,but very close.
Моя проблема
Lack of anger mgt. Threw s5 at wall, wall won!
Моё решение
Way faster than I expected.
Мой совет
magnifying glasses and plenty of white light. Watch several videos there are several ways to skin a samsung, I used parts of all the ones I watched.
Моя проблема
I used the Jimmy and Metal Spudger Set to remove the Glass from a Samsung S3.
Моё решение
unfortunately the Cracks in the glass where all the way through the LCD, the the tools worked great. The Jimmy as used almost exclusively.
Мой совет
Humm, well if your glass is very shattered take your time to get all the center glas . . .
Моя проблема
Wanted to speed up my iMac performance. The RAM was already maxed, so the only thing left to do was upgrade the what's drive to an SSD.
Моё решение
It was pretty smooth. Much easier than I thought it would be.
Мой совет
I think it's worthwhile to upgrade the ram & SSD on your older Mac before going out and buying a new one . . .
Моя проблема
Friend needed new screen assembly replacement
Моё решение
Followed the directions, warning stated " not for the faint of heart"!
So iread it over and over, it was dificult had a question ifixit answered within 15 minutes.
So pleased perfect results, so happy and productive and now i have some experience with one . . .
Показать еще
