P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone / iFixit - Made in Germany / New
  • P2 Pentalobe Screwdriver iPhone / Moody - Made in USA / New
8,99 $
8,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Истории ремонта
Моя проблема
Input via digitizer became intermittently erratic. I could scroll screen with finger above screen not touching. Pressing one area made phone act like I had pressed a different area. There was a light streak down screen. This problem was intermittent and would come and go while phone was just sit . . .
Моя проблема
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
Моё решение
Super simple! Make sure that you have that pentalobe (?) screw driver.
Мой совет
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
Моя проблема
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
Моё решение
Very well.
Мой совет
NA
Моя проблема
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
Моё решение
Perfectly
Мой совет
Saw a video on you tube
Моя проблема
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
Моё решение
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
Мой совет
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
Моя проблема
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
Моё решение
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
Моя проблема
I water damaged my 6s.
Моё решение
It went great!
Мой совет
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
Моя проблема
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
Моё решение
Took less than a minute, super super easy
Мой совет
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
Моя проблема
screen cracked
Моё решение
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
Моя проблема
Cracked display
Моё решение
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
Мой совет
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
Показать еще
