Tri-point Y0 Screwdriver
  • Tri-point Y0 Screwdriver / iFixit - Made in Germany / Fixed Blade
  • Tri-point Y0 Screwdriver / Moody - Made in USA / Fixed Blade
8,99 $
8,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Use this precision Tri-point Y0 DIY or professional electronics repair. Slightly different from a "tri-wing", this driver fits some of the smaller "tri" screws found on Apple track pads and other products.
The iFixit Tri-point Y0 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Tri-point Y0 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Истории ремонта
Моя проблема
The battery was almost 9 years old and only had 57% charge capacity left.
Моё решение
The repair was very simple. I believe it took longer to restart the laptop then to do the replacement.
Мой совет
Make sure to read, understand and follow the directions in the guide.
Моя проблема
2 problems: First, battery losing life, then computer could not communicate with hard drive.
Моё решение
Went well. The drive cable was a bit of a challenge because of the need to bend it at sharp right angles to fit stair-step in upper case where it gets fastened with screws, but after several tries, got it to . . .
Моя проблема
Battery was completely dead
Моё решение
Super easy and very helpful guide to understand and follow
Мой совет
You guys do great work thanks!
Моя проблема
Original battery was swollen
Моё решение
Nice and simple
Мой совет
Be sure to read the guide. There was one connector I originally overlooked that the guide pointed out.
Have the right tools. The screws that hold the battery in place would be badly damaged and likely the screwdriver I used would be too.
Моя проблема
Electrical part which had a relative simple problem to fix.
Моё решение
Very well - as expected.
Мой совет
When unsuccessful finding the appropriate tool at the local hardware store, go to the internet - especially the iFixit website.
Моя проблема
No problem, only self install 0,35$/GB common ssd Instead of 3 times the price of Apple's ssd...
Моё решение
Good. ifixit video tutorial + adhesive parts make it easy
Мой совет
Carefully remove the bottom Edge adhesive. Don't use a cutter to cut it , Risk of scratching the back of the bottom glass panel edge , (visible on . . .
Моя проблема
Only my grandson knows
Моё решение
Hasn't started yet-- gets parts Dec. 25
Мой совет
Ask for recipients email
Моя проблема
Screen was broken and I decided to fix it instead of replacing the whole unit.
Моё решение
We followed the instructions step by step and it went very well. The phillips screwdriver ended up not really working on the first set of screws but i had another that was better but other than that everything went really . . .
Моя проблема
have used ifixit site before and was very pleased with outcome
Моё решение
the repair went smoothly; my trackpad repair came without the cable so i needed to swap that over so there should be a couple of pics on how to do that
Мой совет
don't be afraid to tackle such a project; plenty of guides and tools available to do th . . .
Моя проблема
My trackpad had become extremely hard to click and took a lot of force to do any clicking. So, I decided to replace the pad and upgrade the RAM while I was inside the computer.
Моё решение
The repair was simple and easy and took about 25 minutes to complete. I even did a lot of cleaning inside the computer while . . .
Показать еще
