Universal Bit Kit
Universal Bit Kit
The complete bit set for any repair enthusiast.
$85.99
$85.99
Мы отправим сообщение, когда товар будет в наличии.
Новая батарея = более быстрый iPhone
Наборы исправлений Начиная с $16.99
Спецификации
Параметры
Параметры
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
Видео о продукте
Истории ремонта
Фото профиля
Benjamin Rodriguez's Story Photo #1013595
Моя проблема
Battery is damaged
Моё решение
Quite easy
Мой совет
If you put more guides that are good to learn
Фото профиля
Моя проблема
User spilled coffee onto their keyboard, computer shut off.
Моё решение
Better than anticipated. First in hour repair of a logicboard.
Мой совет
Magnetic board to organize screws and the 128-bit kit to have everything.
Фото профиля
Моя проблема
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
Моё решение
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
Фото профиля
Моя проблема
The Problem started when my dog knock over water on my wife mac.
Моё решение
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
Мой совет
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
Фото профиля
Моя проблема
It had been dropped
Моё решение
My blind grandmother could have fixed it....
Мой совет
If you need help go to ifixit
Фото профиля
Моя проблема
The battery of my Macbook Pro 15 - 2011 died on me.
Моё решение
It took about 7 min and was great.
Мой совет
Just read the instruction before you order.
Фото профиля
Моя проблема
The current 500GB drive had run out of space, so we upgraded to 4T.
Моё решение
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
Мой совет
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
Фото профиля
Моя проблема
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
Моё решение
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
Мой совет
Oh yes, advice... . . .
Показать еще
