Xbox 360 Opening Tool
  • Xbox 360 Opening Tool
4,99 $
4,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Used to open the plastic outer casing of the Xbox 360.
Истории ремонта
Моя проблема
Tray replacement
Моё решение
The xbox opener tool is the end all be all when it comes to opening these things. opened quite a few of them, and it is a coin toss as to whether or not the case will disintigrate, or bite you back. the opener removes all doubt. seperated the back plates as smooth as butter.
Мой совет
use the t . . .
Моя проблема
Well this one specifically helped with repairing a bricked, 360. However the real purpose was putting together a toolbox.
Моё решение
Went great, resurrected an '07 360 (Dead DVD), and it finally was able to see firmware beyond the Blade style dashboard.
Мой совет
Nothing on my end, keep up the great site.
Моя проблема
The DVD tray was stuck open after the XBox 360 was dropped.
Моё решение
I was able to remove the DVD and place the tray back successfully. The dvd games cannot be read and played and I need to take the DVD out to see if I need to replace the laser unit.
Are there any instructions available on how to use the . . .
Моя проблема
After a big lightning storm, I could not sync my wireless controllers and the ring lights would not come on. RF Board fried.
Моё решение
The tools made getting to the fried RF Board really easy.
Мой совет
While I was at it I ended up replacing the green lights with blue ones. I had bought a cheap RF Board with blue lights . . .
Моя проблема
Wireless controllers would not sync with Xbox 360 and the power light would not come on.
Моё решение
The repair went well except for the Spudger tip broke almost immediately- very disappointed with that. IFixit guide was extremely helpful and assisted me in successfully installing a new RF Module board on my 3 . . .
Моя проблема
Xbox disk read error.
Моё решение
Easy
Мой совет
Make sure you open the xbox first so you get the right drive.
Моя проблема
A friend gave me a RROD'd original Xbox 360.
Моё решение
I read several guides and decided to use the 8-penny method (Pushing up the mobo at the RAM with make-shift stints) and then turned it back on and let it run with air-flow blocked to the GPU for ten minutes. After a couple hours, to let it cool, I turned . . .
Моя проблема
My friend's Xbox 360 Elite recently got the dreaded "Can't open tray" error. Unfortunately, he tried to manually remove the disk (incorrectly, but what can I say?), and the tray both came off-track AND managed to damage the tray motor. It was very clear that the drive was toast. He called me, asking . . .
Моя проблема
I fix my Xbox 360 in order to save money if I can and I didn't want to recycle it unless there was a way to fix it.
Моё решение
It was little difficult to fix the problem but it help me get the Xbox 360 working again.
Мой совет
Just relax while repairing your console and take one step at a time and don't rush it.
Моя проблема
cause it was already open pass warranty
Моё решение
great it worked
Мой совет
nope, worked good
Показать еще
