iMac Service Wedge
  • iMac Service Wedge / New
  • 360°
360
iMac Service Wedge
12,99 $
12,99 $
Мы отправим сообщение, когда товар будет в наличии.
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Спецификации
Описание
Описание
Hold your iMac in place
  • iMacs are designed to be superbly balanced when all their parts are in place. However, once the heavy display is removed, they become unbalanced and difficult to work on.
  • This foam wedge holds the iMac in the perfect position for turning screws, lifting components, and routing cables. No flop, no slop.
  • Compatible replacement for Apple Part 944-4365
Совместимость
iMac 27" 2017
EMC 3070 3.4 GHz
EMC 3070 3.5 GHz
EMC 3070 3.8 GHz
EMC 3070 4.2 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 20" EMC 2266 (Edu)
iMac Intel 20" EMC 2316 (Edu)
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 21.5" EMC 2428
2.5 GHz (Mid 2011)
2.7 GHz (Mid 2011)
2.8 GHz (Mid 2011)
iMac Intel 21.5" EMC 2496 (Edu)
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Late 2015)
2.8 GHz (Late 2015)
iMac Intel 21.5" EMC 3068
EMC 3068 non 4K 2.3 GHz
iMac Intel 21.5" Retina 4K Display (2015)
EMC 2833 3.1 GHz
EMC 2833 3.3 GHz
iMac Intel 21.5" Retina 4K Display (2017)
EMC 3069 3.0 GHz
EMC 3069 3.4 GHz
EMC 3069 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
iMac Intel 27" EMC 2429
2.7 GHz (Mid 2011)
3.1 GHz (Mid 2011)
3.4 GHz (Mid 2011)
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5k Display
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
EMC 2834 3.2 GHz (Late 2015)
EMC 2834 3.3 GHz (Late 2015)
EMC 2834 4.0 GHz (Late 2015)
iMac Pro
EMC 3144 2.3 GHz (Late 2017)
EMC 3144 2.5 GHz (Late 2017)
EMC 3144 3.0 GHz (Late 2017)
EMC 3144 3.2 GHz (Late 2017)
Показать еще 26 устройств
Истории ремонта
Фото профиля
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
Моя проблема
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
Моё решение
It went smooth, thanks to iFixit guides, videos, and tools
Мой совет
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
Фото профиля
loucioccio's Story Photo #880618
Моя проблема
The 1TB hard drive gave a SMART warning through Tech Tools Pro. So taking no chances I used Bombich Carbon Copy Cloner to make a backup and restore partition. This was a good idea as I would have to make a Fusion Drive as the iMac originally had the 1TB Fusion using terminal in the restore partition . . .
Фото профиля
Моя проблема
I upgraded the RAM and the hard-drive (8 GB - 32GB, and 1 TB HDD to 500 GB SSD)
Моё решение
The repair went very well. The directions were great. I was surprised at how easy it was to remove and reattach the glass display.
Мой совет
1) The provided screwdriver contains extra bits in its top cap. I didn't realize this. It d . . .
Фото профиля
Моя проблема
Broken glass impelled me to buy a replacement and iFixit tool kit 2 years ago. Then I read about the iFixit SSD harness, so... put in a SanDisk 128 SSD with IFixit hard drive. Problems, problems.
My issues with the earlier installation were:
1. bent / broke display data plug teeth twice reinstal . . .
Фото профиля
Моя проблема
to replace my 27" iMac 1TB HDD with Samsung 850 PRO 512 SSD
Моё решение
It went perfect; thanks to iFixit guides and videos
Мой совет
take your time to prepare for this, a clean area and quiet place will help a lot. handle the screen with extra care, and there's no actual need to remove the left speaker completely if you j . . .
Фото профиля
Моя проблема
Everything breaks eventually and we get asked to fix it. We needed some good tools for our computer repair center.
Моё решение
These tools are going to make our jobs easier. We've used them for a few projects already and we suspect they'll last us years and headaches to come.
Мой совет
Go with iFixit branded tools. They wo . . .
Фото профиля
Моя проблема
Hard Drive was going bad and I thought I would replace the Ram and upgrade at same time
Моё решение
Repair went well thanks to Fix it and the Guides
Мой совет
I didn't take the motherboard out but replaced the Ram in place
Фото профиля
Моя проблема
Hard Drive Upgrade
Моё решение
Great
Мой совет
Patience
Фото профиля
Моя проблема
We have encountered an issue with Apple's fusion drive, where if you work move masses amounts of files on a daily basis, the drive will come to a crawling halt. We have an identical iMac with SSD where this issue didn't happen. Replacing the Fusion Drive with an SSD - best move ever and a new lease . . .
Показать еще
