iSesamo Opening Tool
  • iSesamo Opening Tool
  • 360°
360
9,99 $
9,99 $
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Crafted for one purpose
A thin sheet of springy steel, designed to slide easily between panels and into microscopic cracks. An expertly curved tip, perfected to get the right angle on electronic casing clips. And with a no-slip grip, this tool is much more effective and reliable than other case opening methods.
  • This tough tool nimbly pops open modern small electronics casings.
  • Springy steel blade features a smart tip design and a handle with a great no-slip grip.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Видео о продукте
Истории ремонта
tomm's Story Photo #1334078
Моя проблема
iPod Photo purchased when first released. Replaced battery using iFixit parts, tools, and guide six or seven years ago. That battery started quitting when indicating about 1/2 charged. Decided time to fix it again.
Моё решение
I couldn't get the case open. Trying from the right side as indicated in the guide . . .
Моя проблема
Yes I’m learning how to repair iPhones with these tools. Thank you!
Моё решение
It went good
Мой совет
I fixed an iPhone 5s
Моя проблема
My phone got dropped at the airport and cracked the upper left corner of just the glass, still worked fine, but I researched changing the glass only and most of the feedback indicated that you'd damage the digitizer in the process so I opted to order the screen and digitizer assembly. My wife had d . . .
Моя проблема
Reemplace el conector de carga, la guía me sirvió mucho :)
Моё решение
Fue un poco complicada pero al fin y al cabo logré la reparación
Мой совет
Usen una luz blanca para prestar atención al lcd, este se podría quemar por el calor
Моя проблема
An older iPhone 4 with a cracked screen was going to waist in my dresser. I found myself reading for it when my new fone was on the charger but e screen was a mess.
Моё решение
The repair wint great. No issues not if is a pleasure to use for late nite browsing and email. I forgot hi good the smal screen actu . . .
Моя проблема
My iphone 6 screen was broken and i bought from another seller and it appeared to be of poor quality so i decided to buy from ifixit and it went all well
Моё решение
Smooth. I had the islack which works like a charm. Easy to open the iphone
Мой совет
Buy from reliable sources like ifixit
Моя проблема
My daughter cracked her iPhone 5S screen while at college after only having the phone for about 5 months. I decided I would fix it myself while she was home for Christmas break. I also decided that while I was at it, I would fix her older iPhone 4S cracked screen and sell that phone to help pay fo . . .
Моя проблема
I was tasked with replacing the battery in 14 Ipad Gen 1's - That seemed easy enough, since I'd been repairing PC for Years.
Моё решение
The Repair started out ok I received my tools, and went right to work, using the iSesamo Tool I opened the first ipad pretty easy, The only issue I have with the iSesamo Tool i . . .
Моя проблема
The charging port on my iPhone 5 was shorted.
Моё решение
After looking at the repair guide for a while, I managed to open and fix the iPone for the first time in about an hour.
Мой совет
Pay attention to how you remove the loudspeaker. That almost tripped me up while reinstalling.
Моя проблема
Wacko iPad decided to fly out of my hand. All went well for about 2 seconds, then it fell down a flight of concrete and steel stairs.
Моё решение
All went as described. My only problem was the chassis was somewhat deformed at the corners, causing some difficulty fitting the bezel. Turned out okay though.
Мой совет
Dry fit . . .
Показать еще
