« Обратно ко всем историям
Posix errors, unmountable drive error, new drive unrecognized
Edward Castillo -
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement
30 мин.
Easy
Моя проблема
MacBook Pro had screen with grey apple and spinning pinwheel. Refused to start from drive. Tried to reinstall with Mac OSx setup DVD but would not install due to "unknown error." Could not run repair with Utilities due "unmount able" drive error. Purchased new Maxtor 320 gb drive and OSx setup could not recognize it.
Моё решение
Then I connected the old 160 gb drive externally via USB enclosure and mac OSx setup recognized it and was able to repair some errors. After connecting the new 320 gb drive externally, via USB, I was able to partition, format, and finally install Snow leopard, allowing the mac to boot up.
This led me to think the system board had I/O issues with hard disk so I bought the internal SATA cable and was pleasantly surprised that this fixed the issue!
Мой совет
If you connected the drive externally like I did, make sure that when you put it internally with the new SATA cable that you disconnect the internal battery connector, that goes to the board, with your plastic spudger.
Then boot into the setup DVD and run Utilities so that you can run the repair option so that it can verify all is OK and set it up to recognize it as the internal primary startup device.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable Изображение
$34.99
Комментариев: 0
Добавить комментарий
