MagSafe2 DC inboard replacement on MBPrRetina mid-2012
Моя проблема
MacBook not charging
Моё решение
The repair went pretty smoothly. The trickiest part was removing the keyboard ribbon cable. The instructions were not clear to show the actual location of the section that you have to flip up. With patience it wasn't too difficult to figure out. The project tray came in very handy to place parts and screws in order of disassembly making reassembly simple.
Мой совет
Use the project tray to sort and keep parts in order and carefully make note of which screws go where particularly with the fans and the logic board. Also when re-installing the logic board make sure none of the ribbon connectors are trapped underneath it before you screw it down.
0 Комментариев
