Is it possible to change a capacitor?
pirmil -
Моя проблема
Panne complète du MacBookPro. Complete failure, the Mac will not boot!
Моё решение
Démontage relativement facile. Excepté le connecteur des ventilateurs.
Relatively easy disassembly. Except fan connectors
Мой совет
Une question. Est-il difficile de remplacer le composant [68 C3N] qui a brulé ?
A question. Is it difficult to replace the component [68 C3N] who burned?
Один комментарий
Totally possible. Take a look on the tutos by Louis Rossmann: https://www.youtube.com/channel/UCl2mFZo...
His videos are so long sometimes but you learn a lot.
Be careful!! If you are not experienced on soldering don't attempt to change this tiny devices. You better practice a bit before doing so.
Alex - Ответить
