Моя проблема
Battery was dying within an hour of a full charge.
Моё решение
Taking apart the iPhone was fine! I was glad I had three small bowls prepped to hold the TINY screws. Putting it back together was not so much fun. One screw decided to fall between the battery and the plate over the display case ribbons. I had to take it apart to retrieve it. It took LOTS of finagling to get those three tiny screws for the display case ribbon cover in place.
Мой совет
Make sure the area is clear so if you do drop one of those screws you can easily find it. I wonder if the magnetic pad would make it easier to grab the screw in position for placing it and screwing it down?
0 Комментариев
