Моя проблема
Bad /Old Battery. Replace Display (not part of original problem :-(
Моё решение
The repair went fairly smooth. The only problems I had were removing the adhesive underneath the battery because it kept breaking and and putting the display back on - I broke it... However the solutions are explained in the troubleshooting sections but I didn't think to look there until it was too late. 2nd time assembly is always easier :-)
Мой совет
Putting the display back on requires even pressure after the front tabs are inserted. Watch/read the troubleshooting section. Also, some replacement displays with the "HOME" button cannot do fingerprint scans so remove it from the original display.
0 Комментариев
