« Обратно ко всем историям
Quickly repair cracks in laptop shells - a low-cost solution to save money
CC wang -
Картинка к истории
Моя проблема
1. Cost issue: It is too expensive to replace the entire bottom shell of a branded machine, and the actual damage is only a local area near the hinge.
2. Environmental considerations: 30% of electronic waste comes from "structural damage" that can be repaired.
Моё решение
I referred to the "Notebook shell structural repair" guide on the Tengzhong (https://tengzhongtec.com/) website, and the blog on the website also has detailed solutions.
1. Test model: HP EliteBook 840
2. Time: 15 minutes/unit
3. Durability test: Pass 5,000 opening and closing cycles
Мой совет
Make protective preparations in advance, such as sticking aramid fiber tape on the hinge position, which can prevent 80% of breaks.
If you need to do high-volume repairs, look for a supplier that uses UV-cured epoxy, which can be 300% more efficient.
Moray Driver Kit Изображение
Moray Driver Kit
$19.95
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 17
За последние 30 дней: 42
За всё время: 42
