« Обратно ко всем историям
Bringing a Refurbished Gas Chromatography System Back to Life
spectra chrome -
Картинка к истории
  • Изображение #1
  • Изображение #2
Моя проблема
A pharmaceutical quality control laboratory approached us with a Gas Chromatography (GC) system that was experiencing unstable baseline readings, inconsistent retention times, and frequent injector-related errors. The instrument had been out of service for several months, causing delays in routine sample analysis and increasing operational costs. Since purchasing a new GC system would require a substantial investment, the laboratory opted for a complete refurbishment and repair solution.
Моё решение
The refurbishment process began with a comprehensive inspection of the instrument. Several worn consumable parts were identified, including septa, liners, gas filters, and tubing connections. The injector assembly was cleaned and rebuilt, while the detector was serviced and recalibrated. We also replaced aging electronic components showing signs of instability. After reassembly, the gas flow paths were leak-tested and optimized. The instrument software was updated, and multiple performance qualification runs were conducted using standard reference compounds. Following calibration and validation, the system demonstrated excellent repeatability, stable baselines, and accurate peak resolution.
The entire refurbishment process was completed efficiently, allowing the laboratory to resume analytical operations with minimal downtime.
Мой совет
Regular preventive maintenance is far more cost-effective than waiting for a complete system failure. Laboratories should schedule routine inspections, replace consumables proactively, and monitor baseline stability to identify issues before they become critical. Refurbished analytical instruments can deliver excellent performance when serviced by experienced professionals and validated properly before use.
https://www.spectrachrome.in/products
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 4
