« Обратно ко всем историям
13 inch 2011 speaker replacement
danimazilu -
MacBook Pro 13" Unibody Early 2011
MacBook Pro 13" Unibody Early 2011 Right Speaker/Subwoofer Replacement
15 - 30 мин.
Moderate
Моя проблема
The subwoofer stopped working,I think that it might have been my fault-I played music for about 3 hours with VLC .The sound was amplified at 200%,there was no distortion,but it killed it.
Моё решение
It took me about an hour to replace both.The screws are very small,an you have to be carefull with cable routing,when you put it back together.Also when I detached the speaker,the metalic plate underneath it moved-you need to hold it in place.
It works just as good as the original.Nice replacement
Мой совет
magnetic screwdriver helps a lot with the small screws
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Subwoofer and Right Speaker Изображение
$29.99
0 Комментариев
Добавить комментарий
