« Обратно ко всем историям
Just removing the hard drive is fewer steps
Aptegra -
Моя проблема
Needed to temporarily remove the hard drive to perform forensic imaging.
Моё решение
Went great. Excellent guide and tips.
Мой совет
You don't need to undo all the cables. Once you've got past step 5 (disconnect vertical sync cable), you can simply prop up the screen, remove the SATA connectors (data and power), and remove 2 screws holding in the drive.
Since I was just imaging the drive and it could connect easily to my write blocker, I didn't need to remove anything else from it. Simplicity itself. Easy out, easy back in.
Spudger Изображение
Spudger
$3.99
Heavy-Duty Suction Cups (Pair) Изображение
$14.95
Mako Driver Kit - 64 Precision Bits Изображение
$39.95
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4
