Моя проблема
Malfunction as of spilling red wine over keyboard
Моё решение
Great guide, the comments are the best part of it, alas I found them afterwards
Some screws (4x) were very tight and therefore damaged and difficult to remove (picture 1)
I used a needle file to create new grip and remove them
The battery cable connector (picture 2) also damaged
the picture in the guide suggests to pry at the corner, better try this slowly with different angles of attack
Luckily it operated normal in spite of the damage
The speaker connector also damaged (picture 3)
removal of the connector should be done very careful
it took some time to reinstall it in the proper way
Installing the track pad
So glad I came this far and tightened the T6 Torx screw of the track pad without checking... Experienced it during boot up, everything had to be done over again (second time was much easier)
Keyboard ribbon cable (picture 2)
though I installed it the right way
By placing the battery afterwards the cable is easily displaced and the Mac Book won't boot up
So I had to remove the under case for the third time
The lower case is constructed of rubber-coated aluminum.
the rubber coating gets lose when removing the lower case multiple times… (picture 4)
With the metal spudger the job was done
and YES in the end everything worked as it should. I fixed it !!
Мой совет
Read the guide thoroughly AND ALL the comments before you even start
0 Комментариев
