Выберете то, что вам нужно
Flip the unit upside down to access the six screws on the bottom.
Remove the six screws indicated with a Phillips-head screwdriver. All the screws are of the same length.
Unplug the laser assembly's power cable and ribbon cable from the main board.
Remove the two screws on the memory card/controller port, disconnect the ribbon cable, and lift it out of the case.
To remove the power supply, disconnect the cable and remove the two screws, then lift it out of the case.
Replace the top shield, and secure with the 3 screws indicated.
Reinstall the memory card / controller module. Connect the ribbon cable and replace the 2 screws.
Align the optical drive assembly with the three pegs.
Reconnect the power and data cables for the optical drive.
Slide the cover on the system in the same way you took it off and replace the black screws indicated.
