Инструменты для этого Разбора
Введение
Here you will see a breakdown of the Apple Studio Display M2454. This will be useful in repairing broken or malfunctioning parts in the future.
Notice that the main components of the monitor are only accessible from the back of the device.
Locate the four hex head screws located on the corners of the back panel.
Remove the screws with a 2mm hex screwdriver.
To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
Remove connector connected to the hold down previously removed simply by pulling with hand.
Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
