Fix Your Stuff
Right to Repair
Parts & Tools
Инструменты для этого Разбора
Введение
Here you will see a breakdown of the Apple Studio Display M2454. This will be useful in repairing broken or malfunctioning parts in the future.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Apple Studio Display M2454, воспользуйтесь нашим сервисным руководством.
  1. Notice that the main components of the monitor are only accessible from the back of the device.
    • Notice that the main components of the monitor are only accessible from the back of the device.
  2. Locate the four hex head screws located on the corners of the back panel.
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  3. Remove the clear and gray back panels.
    • Remove the clear and gray back panels.
  4. Remove the three screws with #2 phillips head screwdriver.
    • Remove the three screws with #2 phillips head screwdriver.
  5. To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
    • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  6. Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
    • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  7. Remove the four screws on the metal bracket.
    • Remove the four screws on the metal bracket.
  8. Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
    • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  9. Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
    • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  10. Remove white connector by lifting tab and pulling away from board.
    • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
  11. Remove connector connected to the hold down previously removed simply by pulling with hand.
    • Remove connector connected to the hold down previously removed simply by pulling with hand.
  12. Now that the main computer cable is detached, remove it away from monitor.
    • Now that the main computer cable is detached, remove it away from monitor.
  13. Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
    • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  14. Remove the screw on the wire hold down with #2 Phillips head screwdriver.
    • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  15. Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
    • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  16. The USB port is now detached, remove it from monitor.
    • The USB port is now detached, remove it from monitor.
  17. Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
    • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  18. Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
    • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  19. Remove top right connector of the LCD main board by pulling with hand.
    • Remove top right connector of the LCD main board by pulling with hand.
  20. Remove the final connector of the LCD main board by pulling with hand.
    • Remove the final connector of the LCD main board by pulling with hand.
  21. Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
    • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  22. The board is now detached, remove it from monitor.
    • The board is now detached, remove it from monitor.
  23. Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
  24. Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
    • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  25. The CCFL inverter is now detached, remove it from monitor.
    • The CCFL inverter is now detached, remove it from monitor.
  26. You have now successfully taken apart a Apple Studio Display M2454.
    • You have now successfully taken apart a Apple Studio Display M2454.
Dylan Perry
Участник с: 20.01.2010
129 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 13-27, Maness Winter 2010 Участник Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 членов
Автор 9 руководств
Комментариев: 3
This model is also known as the Apple Studio Display 15" LCD.
analogcd - Ответить
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - Ответить
Failing caps were the main problem with this — no air flow.
Mal - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 6,230
