Эта разборка продолжается – Периодически обновляйте, чтобы увидеть последние изменения!
Выберете то, что вам нужно
Видео обзор
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: шаг 1, изображение 1 из 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: шаг 1, изображение 2 из 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: шаг 1, изображение 3 из 3
    • The back panel is removed.
    • The SSD is removed.
IT FIX
Участник с: 10/16/17
6 340 Репутация
Автор 74 руководств
12 Комментариев
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - Ответить
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - Ответить
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - Ответить
It’s very easy but it’s supports only M.2 SSDs
IT FIX - Ответить
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - Ответить
I am currently having the same problem. I cleaned the fan and there seemed to be no dust when cleaning. After restarting my laptop it continues, I am also curious at to what the problem is.
Leng Her -
Hey,
I have the same problem. Did you fix it?
Leonard •ᴗ• -
Great - my fan is also making rattling noises. I would really like to know how to fix it.
Eike Decker -
I'm having the same problem, will try to clean it and fix the fan, i think it's a fan issue, it should be crooked
David Chong -
Hello, iFixit! What size / number of screwdriver bit (4mm or 1,4’’ Torx (for example T2, T3, T4, T5) ) to open the ultrabook’s case?
Вячеслав Мурзин - Ответить
привет, вячеслав мурзин,
давно это было но мне кажется это был t5
IT FIX -
So you have not made any progress from 2018?
Kind-hearted, spirited Man - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 46
За всё время: 6,469
