This teardown is in progress – Reload periodically to see the latest changes!
Danger
Потенциальная опасность
При несоблюдении этих указаний техники безопасности, может возникнуть травма. Будьте внимательны и следуйте всем указаниям.
Danger
Инструменты для этого Разбора
  1. The Assembled Product, unplugged from wall
    • The Assembled Product, unplugged from wall
  2. Turn Smart Strip upside down and locate  four screw holes in corners Unscrew four corner screws with #0 Phillips Screwdriver
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. Locate four latch slots in case Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Take two halves of case apart with your hands Take two halves of case apart with your hands
    • Take two halves of case apart with your hands
  6. Lift Ground Copper Strip upward off of power plugs by hand
    • Lift Ground Copper Strip upward off of power plugs by hand
  7. Locate latch securing power plugs to bottom of case Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  8. Lift power plugs out of bottom of case along with circuit assembly Lift power plugs out of bottom of case along with circuit assembly
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
Участник с: 14.11.2013
194 Репутация
1 Guide authored
Комментариев: 2
This is great! Thanks so much!
nils smith - Ответить
that awesome and i like how it fix
Joseph donkor - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 10
За всё время: 1,110
