Введение
This fine computing device was recently discovered in an undisclosed warehouse where it was being studied by Top... Men.
What could be lurking inside this heavy metal box? A Golden Idol... The Ark of the Covenant... Giant Ants?
These are all possibilities, but there's only one way to find out for sure.
Выберете то, что вам нужно
Behold, the power of beige!
Tech Specs:
933 MHz Pentium III Processor
10 GB PATA Hard Disk
512 MB of PC133 RAM
16x DVD-ROM and 3.5" Floppy Drive
Life Experience
Some of these ports belong in a museum:
RS-232 Serial
DB-25 Parallel
PS/2
DE-15 VGA (oh, wait...)
The antenna is a pretty big clue that this computer has been upgraded at some point.
We're going to remove the heavy steel casing by pressing in on the tabs located on the sides of the cover and then pulling the cover forward.
There are a few hooks holding the cover in place, so some rocking is necessary to free it.
With the cover removed, we are greeted by some ancient hieroglyphics. Green tabs and arrows identify how the rest of the major components can be removed.
A diagram of the motherboard and common diagnostic codes can be found on the interior of the chassis cover.
The various drives are mounted on a single hinge that flips forward. Just pull up and it will click into place.
The PCI riser is one of the few things missing a green label. The release button is the silver tab towards the front of the computer.
The power supply swivels up and away from the motherboard.
Time to remove those pesky cables. We'll want to be careful since PATA ribbon cables have many pins that can be bent.
Tape. Why'd it have to be tape?
Each drive has its own metal tab located in the center of the hinged bracket.
Removing the various drives is just a matter of pressing the metal tab and sliding the drive out.
The next step is to remove the power supply.
Disconnect the 14 pin ATX connector from the motherboard. (Look for the festively colored cable.)
A single T5 Torx screw holds the power supply to the chassis.
A few more cables need to be disconnected before the motherboard can be removed.
The speaker cable has a red and black wire.
The solenoid cable has three white wires.
The serial cable is a small gray ribbon. The connector is marked as "Flying Serial" on the motherboard.
It's finally time to remove the motherboard!
We'll start by releasing the I/O port bracket on the back of the computer.
Six support pegs are now the only thing holding the motherboard in place.
Slide the board towards the back of the computer and lift up once the pegs are free.
Four 8 mm hex nuts are the only thing keeping this beast of a sound system attached to the chassis.
Take a moment to admire the motherboard in all its glory!
In lieu of a dedicated video card, the Intel 815 chipset utilizes an integrated graphics solution. Needless to say, gaming on this machine would be painful at best.
The RAM can be removed by unlocking the white tabs on each end of the modules and pulling up.
The first step in removing the CPU cooler is to unplug the small three pin power cable.
The CPU cooler is attached to the socket with metal hooks. Removing it without damaging the CPU requires two distinct motions:
Gently push down on the red tab.
Squeeze the red tab towards the fan and then lift the cooler.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Removing the CPU requires a steady hand and can be slightly intimidating.
A beige lever keeps the CPU locked in place. Pull it away from the processor and then up. The processor will move towards the group of capacitors when it is unlocked.
The processor can be removed from the socket by gripping the edges and pulling straight up.
It's time to return to the PCI riser now that we've run out of things to take apart on the motherboard.
The riser has space for three additional PCI cards that are each secured with a single T5 Torx screw.
A quick pull is all that is needed to remove each card.
That's it. Now we just need to reassemble it before someone realizes it's not in the warehouse.
Completely Unofficial Compaq Deskpro EN Repairability Score: 10 out of 10 (10 is easiest to repair)
It practically tells you how to disassemble it.
Most common repairs can be done with one tool.
Faces remain unmelted after removing the cover. (Always a good thing.)
Finding replacement parts may require entering a Temple of Doom/RadioShack.
5 Комментариев
Personally I’d include ease of finding suitable replacement parts in a reparability score, I’ve worked on these things and would rate them at 8.5-9.5 for non-standard motherboard, motherboard mountings, and power supply.
If purchasing rather than leasing, I think the point was retire the first few that break out of warranty, and start parting them out. Compaq was very good about keeping the same line going for a long time so the parts would be compatible.
Awesome! I love these machines. I’m pretty sure these ones will run a Tualatin PIII if you upgrade the BIOS too.
do you know, how to oil noisy power supply fan in this computer? I tried but I can’t open it?
Thanks for the quality
this writing style is funny
