Введение
A look at the guts of the iPaq.
Выберете то, что вам нужно
an original ipaq from compaq not hp
the teardown is realatively simple (PS: simply is not always easy)
Gently pry around the edges to release the cover
fold the back under the front panel and carefully remove the battery connector
Disconnect the backlight
from the inverter
here is an Htc branded processor
be sure to pop up the black wire
remove the stylus ejector
Gently pull on the top face while lifting the logic board (will require some force)
Be careful of the black wire running along the board
Disconnect the screen and digitizer cables being careful not to damage the cable or connector
The final product (destroyed that is)
I used NO anti-static precautions, reassembled the device and after finaly getting the video cable to lock in it worked fine
PS: the touch panel worked But when i fixed the video cable i knocked it loose and didnt realize it and now i have to fix it (sigh)
