Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Инструменты для этого Разбора
Введение
Tearing down a Cyclops Helios headlamp. Both hardware identification and functionality for the device are discussed.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Cyclops Helios, воспользуйтесь нашим сервисным руководством.
  1. Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
    • Black button - circled in red
  2. Using two hands, carefully separate the front panel and back panel of the Cyclops Helios. Front panel - boxed in red Back panel - boxed in blue
    • Using two hands, carefully separate the front panel and back panel of the Cyclops Helios.
    • Front panel - boxed in red
    • Back panel - boxed in blue
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Use a Phillips head screwdriver to remove two screws from the front panel. The two screws fasten the outer enclosure with the inner electronics of the front panel.
    • Use a Phillips head screwdriver to remove two screws from the front panel.
    • The two screws fasten the outer enclosure with the inner electronics of the front panel.
  5. Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable. Clear plastic lens - boxed in red Plastic button insert - circled in blue
    • Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable.
    • Clear plastic lens - boxed in red
    • Plastic button insert - circled in blue
  6. The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder. Circuit board - boxed in blue Parabolic mirror - boxed in red
    • The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder.
    • Circuit board - boxed in blue
    • Parabolic mirror - boxed in red
    • Battery holder - boxed in green
  7. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder. Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
    • Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
Shaun Koide
Участник с: 14.11.2013
161 Репутация
1 руководство автора
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 662
