Введение
This guide will demonstrate how to apart the Dell Inspiron 15-7559.
Выберете то, что вам нужно
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
Use the blue, plastic opening tool to gently pry a section of the back panel open.
Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
After the clips have been disconnected, the back panel can then be easily lifted off the computer.
Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
Using your hand grab the white portion connecting the cables to the battery and disconnect it.
Using your hands, raise the hard drive far enough to disconnect the cables attached to it.
Using your hand grab the black portion connecting the cables to the battery and disconnect it.
Locate the WLAN card. It will be on the right sides of the laptop.
Using a Philips #1 screwdriver, unscrew the 2mm x 3mm screw, holding the WLAN card in place.
Using your hand disconnect the WLAN card by pulling it horizontally along the device.
After the WLAN card has been disconnected, make sure to dethread the wires connecting it so that they sit freely.
Using tweezers pull the metal tab, on the back of LCD connection point, away from it.
Once the metal tab is sufficiently released, pull the black strap to disconnect the LCD.
After the LCD has been disconnected, make sure to dethread the wires connecting it so that they sit freely.
Using the Philips #1 screwdriver, unscrew the 4 x 2mm x 5mm screws, located on the top of the laptop.
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
Once the latch is raised, lift the ribbon cable up and out of the latch.
Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Locate the ribbon cable for the track pad and the power.
For both ribbon cables, use your finger to lift the latches up.
Once the latches are raised, lift the ribbon cables up and out of the latches.
Locate the two screws near the center of the laptop.
Unscrew the 2 x 2.5mm x 5mm screws, using the Philips #1 screwdriver.
Locate the fan connections on both the left and right side of the laptop.
Using your hand grab the white portion and pull it away from the port.
Once the fans are disconnected lift and remove them from the laptop.
Locate the 4 hinge screws at the top of the laptop.
Unscrew the 4 x 2mm x 5mm screws, using the Philips #1 screwdriver.
Remove the screen from the laptop.
Locate the wire that connects the display to the back panel. There will be a sticker with a qr code on it.
Peel the the sticker and pull it back to disconnect the cables.
7 Комментариев
Its really good work and Professional one. You can also expect the same from Ncentric systems which are offering the Computer and Laptop Repairing in Hyderabad
Seems a bit rude of them to make you take out the battery and hard drive in order to get to the fans; I tried to open mine up to dust off the inside, but I dont have a Torx screwdriver on me. Looks like I'll have to come back when I have one
I have the same question, where is the reed/ lid switch located?
Anyone know the size of the screws on the top of the hinge?
