Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Elster REX2 Smart Meter, воспользуйтесь нашим сервисным руководством.
  1. Elster REX2 Smart Meter Teardown, Elster REX2 Smart Meter Teardown: шаг 1, изображение 1 из 1
    • While utility companies prepare to deploy smart meters to everyone, we -- being the resourceful people that we are -- acquired one for all our fans.
    • Introducing the energy meter of the future: the Elster REX2 Watthour meter.
    • The REX2 meter provides several enhancements over non-programmable meters:
    • Nonvolatile memory rated for 1,000,000 write cycles
    • Advanced security with full 128-bit AES encryption
    • Remote upgradeability
    • Support for 900 MHz and 2.4 GHz ZigBee communication
    • Optional: flux capacitor add-on???
  2. Elster REX2 Smart Meter Teardown: шаг 2, изображение 1 из 2 Elster REX2 Smart Meter Teardown: шаг 2, изображение 2 из 2
    • The following teardown features dissection performed either by professionals or people who consider themselves to be professionals. Please do not attempt to recreate or re-enact this teardown unless you're fond of getting into trouble with your power company.
    • Before gaining access to the interior of the meter, you must first break a security seal.
    • Apparently, electric companies don't want you tampering with their meters. Go figure!
    • After removing the security seal, the clear plastic cover lifts off easily with a twist of the wrist.
  3. Elster REX2 Smart Meter Teardown: шаг 3, изображение 1 из 2 Elster REX2 Smart Meter Teardown: шаг 3, изображение 2 из 2
    • Our Elster REX2 smart meter is labeled as Type R2S. The 2S model has an operating voltage rating of 240 V ranging from 192 V to 288 V at a nominal frequency of 60 Hz.
    • Who would've thunk that your watthour meter would have a LAN ID? A LAN ID is required to connect to the IP-based EnergyAxis Smart Grid network.
    • Elster's meters operate on 25 channels across the 902-928 MHz ISM band using a controlled path mesh.
    • A "controlled mesh" network is created when the thousands of smart meters in a city communicate with each other to relay power readings to a gateway device that indirectly channels the readings to a utility company. Elster's meters find the best path between themselves and other meters on the grid so that noise and duplication from repetitive signals is at a minimum. This works so well that only one in ten smart meters is used as a repeater to relay signals from other meters.
    • If a specific household has concerns about their meter being used as a repeater, they can contact their utility company to request that their Elster meter transmits power readings just once a day.
  4. Elster REX2 Smart Meter Teardown: шаг 4, изображение 1 из 2 Elster REX2 Smart Meter Teardown: шаг 4, изображение 2 из 2
    • The two halves of the case are held together with four plastic clips.
    • Once all the clips are depressed, the two halves "pop" apart making access to the internals easier.
    • Separating the two halves provides the first glimpse of the meter's surprising deficiency of internal components.
  5. Elster REX2 Smart Meter Teardown: шаг 5, изображение 1 из 3 Elster REX2 Smart Meter Teardown: шаг 5, изображение 2 из 3 Elster REX2 Smart Meter Teardown: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Large Needle Nose Pliers
    Купить
    • After disconnecting a single cable, we get a good look at the smart meter's power connections.
    • The retaining clips holding the power connections to the back of the rear case are easily removed using our large needle-nose pliers.
    • After a bit of wiggling, the power connections come out with little resistance.
  6. Elster REX2 Smart Meter Teardown: шаг 6, изображение 1 из 3 Elster REX2 Smart Meter Teardown: шаг 6, изображение 2 из 3 Elster REX2 Smart Meter Teardown: шаг 6, изображение 3 из 3
    • Extremely thick copper wires allow the meter to be wired in series with a household's main power supply. They're capable of handling 200 Amps!
    • Interestingly, the meter relies on a black ring-shaped current transformer installed around the copper wires to send power consumption signals to the main board.
    • Current transformers indirectly measure the current flowing through the thick copper conductors and provide an output that can be read by the electronics on the board.
    • Long metal pressure contacts along the inside case of the meter conduct 240V AC electricity to pads that provide power to the main board.
  7. Elster REX2 Smart Meter Teardown: шаг 7, изображение 1 из 2 Elster REX2 Smart Meter Teardown: шаг 7, изображение 2 из 2
    • Well what have we here? Can this be true? In the whole device there is only one screw, a surprisingly difficult to find Phillips #1.
    • After pushing a few clips aside, the motherboard is easily removed from the front case.
  8. Elster REX2 Smart Meter Teardown: шаг 8, изображение 1 из 1
    • Main IC's located on the front side of the motherboard include:
    • Teridian 71M6531F SoC with an MPU core, RTC, FLASH and LCD driver
    • Texas Instruments LM2904 low power dual operational amplifier
    • RMFD RF2172 medium-power high efficiency amplifier IC
    • Texas Instruments CC1110F32 Sub-1GHz System-on-Chip with MCU and 32kB Flash memory
    • Two pads near the top of the board channel 240V AC electricity from the large copper wires onto the board and into the adjacent blue transformer box that steps it down to about 10V AC. From there, the AC voltage is rectified and conditioned to power the DC components on the board.
    "Two pads near the top of the board channel 240V AC electricity from the large copper wires onto the board and into the adjacent blue transformer box that steps it down to about 10V AC. From there, the AC voltage is rectified and conditioned to power the DC components on the board."
    For power metering, the Smart Meter needs the current and voltage waveforms. So these pads are probably for voltage measurement in addition to powering the board.
    Chuck - Ответить
    Where's the encryption key stored into?
    Honam1021 - Ответить
  9. Elster REX2 Smart Meter Teardown: шаг 9, изображение 1 из 1
    • The true innovation in the smart meters is their ability to relay power consumption statistics without direct contact from a meter reader. Our Elster meter accomplishes this by sending encrypted signals on the 900 MHz ISM band. The antenna can be seen on the rear side of the board near its bottom edge.
    • Elster designed the antenna pattern to force signals away from households.
    • Elster meters only relay information when they are spoken to by other meters in the mesh. When they relay information the amount of RF radiation emitted is ~1/4 W, which is less than most cellular phones.
    • Elster designed its meters to transmit data every six hours for 40 ms (.04 seconds) at a time.
  10. Elster REX2 Smart Meter Teardown: шаг 10, изображение 1 из 1
    • The controversy surrounding smart meters is the question of whether the additional radio-frequency (RF) signals will cause any undesired health effects.
    • On one side of the coin, as petitioners have pointed out, smart meters contribute to the already looming cloud of "electro-smog" produced by the multitude of today's devices that produce RF signals.
    • On the other hand, it seems that opponents do not consider the claimed operational characteristics of smart meters. As PG&E points out (they use meters manufactured by GE):
    • Consider that SmartMeters™ transmit only about 45 seconds a day. You'd have to have one of our meters on your home or business for more than 1,000 years to get as much exposure to radio waves as a typical cell phone user gets in just one month.
    • So if the device was always on, 24/7, there might be a cause for concern. But if what PG&E states about the limited transmit time is true, your cellphones, Wi-Fi internet, and microwaves are probably causing your body more damage than a smart meter would. That is, unless you've never used a cellphone or any other device producing radio frequencies.
    They are on 24/7. You cite what PG&E initially claimed. The truth is, smart meters transmit pulses of wireless radiation between 9,600 to 190,000 times per day.. PG&E, the California equivalent of DTE, publicly stated in all its materials that its meters transmit only 6 times a day. When the court ordered it to submit data on the actual number of transmissions, the utility had to admit that its smart meters transmit 9,600 to 190,000 times per day! (PACIFIC GAS AND ELECTRIC COMPANY’S RESPONSE TO ADMINISTRATIVE LAW JUDGE’S OCTOBER 18, 2011 RULING DIRECTING IT TO FILE CLARIFYING RADIO FREQUENCY INFORMATION)
    Smart Meter Education Network - Ответить
    There is a big difference between an average and the actual number of transmissions. In the chart, you will see the line “Meter read data.” This refers to the number of times readings are sent to the utility. That is where the utilities get “6 transmissions per day.” But take a look at the second-to-last line: “Mesh network message management [transmissions].” These transmissions are up to 190,000 times per day. One hundred ninety thousand times is the maximum number of times a single meter sends messages to all the other meters in its area. Think about how many meters are within a two-mile radius of your home and multiply 190,000 by that number.
  11. Elster REX2 Smart Meter Teardown: шаг 11, изображение 1 из 3 Elster REX2 Smart Meter Teardown: шаг 11, изображение 2 из 3 Elster REX2 Smart Meter Teardown: шаг 11, изображение 3 из 3
    • Lastly, we can remove the LCD.
    • As you can see, the monochrome LCD does not have any ribbon cables connecting it to the motherboard.
    • It seems to work via a method of conduction, where the bottom black strip comes into contact with pads on the motherboard, thus producing an image.
    • This method of LCD connection is very common, and the black and pink strip is called a "zebra connector."
  12. Elster REX2 Smart Meter Teardown: шаг 12, изображение 1 из 1
    • Normally we'd assign a Repairability Score on the last step, but we don't feel it's appropriate for this device. After all, there's a tamper-evident security seal for a reason.
    • Even so, we're glad to know that the smart meter doesn't have easily-breakable internal components, and can be serviced without difficulty by an authorized service technician.
    • A big thanks to Elster for providing us one of these meters! We certainly didn't want to take ours off the grid in order to mess around with it.
11 Комментариев
The LCD connector is a commonly used "zebra strip". Multiple parallel (for redundancy)conductive paths in the strip carry the signal to each pad of the LCD glass substrate. These pads are are generally quite transparent. The connections to the display are self-aligning and the zebra strip provides cushioning for the LCD as well.
Jim - Ответить
You state: "So if the device was always on, 24/7, there might be a cause for concern. But if what PG&E states about the limited transmit time is true, your cellphones, Wi-Fi internet, and microwaves are probably causing your body more damage than a smart meter would."
According to PG&E, a Smart Meter transmits on average meter about 45 seconds per day, but could be as high as 14 minutes (875 seconds) per day.. This transmission occurs all throughout the day and night averaging 2 seconds per hour.
But that only tells half of the story.
According to PG&E, there are on average about 10,000 transmission per day (about 7 times per minute) and up to 190,000 times per day (about 132 times per minute). http://blog.sfgate.com/energy/2011/11/03...
The continuous pulsed signals are well-documented in online youtube videos.
This is like getting hit in the head by a sledge hammer once every 8 minutes. Yes, this is cause for concern.
maureen - Ответить
There is no SURGE protection no this beast!
Now let me think!
The Great Technological innovation, is powered by 240VAC, straight off the the power grid, which is susceptible to "Surges" when Lightning activity is taking place in the neighborhood, and transients generated from power outrages being restored, and I see no visible surge protection for the delicate circuitry on the motherboard, or elsewhere in the parts breakdown.
In addition power and signals for the motherboard circuitry is shuttled around by pressure contacts and "Zebra" connectors in an environment exposed to to the temperatures and humidity of the OUTDOORS environment.
Is this some kind of a mystical device, like the "Flux capacitor" of the back in the future slapstick comedy?
Or is it more likely the Elster folks are jesting with the Ignorance of the general public?
Honestly!
Let me ask the question?
What is the MTBF of this toy?
Thirty Seconds after Installation to fire conflagration?
and sixty seconds to errant metering data? Whichever comes first!
I have seen Christmas toys designed better that this abomination of Electronic design Principles.
Fx Greek - Ответить
http://www.forbes.com/sites/williampentl...
5/03/2011 - Not-So-Smart Meters Overbilling Californians
Scores of consumers in California paid for more electricity than they actually used due to errors made by about 1,600 flawed “smart meters” installed by a major investor-owned utility. Ironically, the same “smart meters” were at least partially paid for by California rate-payers with the expectation that the meters would reduce the price paid by end-users for electric power. I suspect the affected customers do not find the irony amusing.
The utility, Pacific Gas and Electric Company, admitted yesterday that about 1,600 so-called “smart meters” had charged customers for phantom power. The meters, manufactured by Landis+Gyr, malfunctioned when they get too hot...
cbturneresq - Ответить
The PGE meters don't transmit only 45 sec per day That is an average.
From WirelessMess.org (and this same info can be found in the Administrative Law Judge's transcript of the hearing): When they say the meter only emits “45 seconds per day” they don’t tell you that means 15,000 pulses.
To record these increments data is transmitted multiple times, every minute, 24 hours a day. If you ask PG&E they will most likely tell you that data is only transmitted six times a day. However PG&E was forced to admit to Administrative Law Judge Yip-Kikugawa that their meters were much stronger than advertised to the public, and each electrical meter puts out bursts of microwave radiation from 9,600 to 190,000 times a day.
The electric meters operate continuously, sending out quick bursts of radiation lasting milliseconds. Considering these bursts are sent out several times a minute, they add up to thousands of bursts all day long.
Utilities use time-averaging to report the meters' power.
Linda - Ответить
I assume the transformer supplying the meter electronics is on the customer side of the current transformer. This will mean the customer pays for the extra electricity used by the meter (around 3W)?
Lindsay - Ответить
Lindsay: The meters have always been arranged so that the voltage coil connections are made AHEAD of the current coil - this way, the small amount of energy expended by the voltage coil (and the meter's internal electronics in today's electronic meters) are NOT included in the consumer's bill - the utility actually eats that cost (which actually is pennies per year per meter anyway).
Fx Greek: The problem with internal surge protection on meters is the amount of 'fault current' available on the utility side of the meter - in some cases, it can be tens of thousands of amps. It was found that there were more failures of electronic meters WITH internal surge protection than without.
Dave D - Ответить
Apparently the smart meters used in Quebec transmit all data in cleartext!
http://anarcat.koumbit.org/2014-03-21-vi...
It's great that the chipset supports encryption, but see that blog for details on how to test your own meter and check that your local utility is actually using it :)
mvc - Ответить
Is the meter powered by the input side of the line, or the output side. If it's on the output side, then it reads it's own usage as well, and we pay for it's use of power (little as it might be).
dewerk - Ответить
Would a more educated …perhap engineer know if this meter has ability to collected kVA readings used to calculate Power Factor.
PF=kW/kVA. …I think?
I have a device collecting inferred power consumption ( watts ) from the 2 main feeding my residence inside house and at entrance panel. .past meter on a 220v service. I have noticed the watts measured over a day can vary from as little as +1.4% or as much as + 41% for any given 1 hour period at my device as compared to elster r2s meter. Meter seems to be always lesser value. Not the close correlation I am seeking. ;-)
I find this interesting as my device ( eyedro.com ) does seem to match spot on …the introduction of know loads( kettle , incandecent lights ..etc ) as measureby a blue planter em100 monitoring a devices (resistive) load kettle, toaster.
Was thinking perhaps my meter ( elsterr2s ) has the ability to also collect kVA. And is making adjustment to wats consumed to corrects for inductive/capacitive loads.
John Fahey - Ответить
what is the maximum lecture in KWh that can do ?
999999? the 000001 ?
thanks
lafoca2772 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 62
За всё время: 67,801
